So I finally performed the pixel fix to my instrument cluster . . .
e320 wagon 1998
The temperature was a PERFECT fix. The clock and gear selector not so much. From what I've read both here and the DIY on benzworld.org this seems to be fairly common. I even had to put 2 shims under the ribbon on the right side but literally no improvement. . .any ideas or comments?
BTW, it was MUCH easier to do than you would have thought from the reading.
Sometimes
the pixels are just plain dead and no ribbon and foam fix will bring them back to life.
![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
put a little tiny cross and a small flower on the side of the road
![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
'00 E430, '83 Porsche 928S
I have fixed two separate clusters so far. On one of them, there were two or three pixels that did not come back. Are a couple of pixels out or is the whole thing dim? Could be a backlight bulb?
e320 wagon 1998
It's kinda weird. . .on the gear indicator, it's 3 pixels now, but it was worse earlier today ![crazy](https://mbworld.org/forums/images/smilies/crazy.gif)
On the clock, it's also 3 or 4 pixels. . .I dunno. Like I said, the temp indicator is perfect!
e320 wagon 1998
Little update
Two weeks on, the right side display is PERFECT. No pixels missing at all. . .must have had to get warm in the car for the connection to occur (?).
