Lower Engine Cover Sailed Away
Old Jul 15, 2008 | 01:22 PM
CrossT's Avatar
CLK430
On a trip to San Diego from Tucson a couple of days ago, my lower engine cover, partially disconnected, began to flap and eventually flew away to the side of the road. Is it a problem to have lost it?
thx
todd
97 E420
Old Jul 16, 2008 | 11:25 AM
RichardM98's Avatar
98 Brilliant Silver E320 Wagon
The primary purpose is sound-proofing and maybe a little aerodynamics. You may hear the engine/trans more at slow speeds and a window open. I assume it tore off. So you'll have to look at the points where it attached to see if the clips pulled out. If so you may need to replace some of the parts it attached to as well as the shroud itself.
Good luck.
Old Jul 16, 2008 | 12:48 PM
ohlord's Avatar
A lot of your engine cooling depends on not having the pressure
under the car so air does not flow backwards through the radiator.Replace the belly pan
Old Jul 16, 2008 | 01:03 PM
lkchris's Avatar
'10 CL550, '12 GL550
This probably often happens to guys who change their oil via the drain plug!
Old Jul 16, 2008 | 01:14 PM
EdzBenz's Avatar
W210 W140
This happened to me because the dealer mechanics are morons and didn't attach the pan properly. It flew off on I-80 going through Iowa. I haven't been able to find a source for the pan. Anybody know of where I can get a used one?
Old Jul 16, 2008 | 06:20 PM
RichardM98's Avatar
Hm... I drove without mine for about a month and didn't notice any increase in engine temp. Anyway MB calls it a sound-proofing panel so that's my story and I'm sticking with it.
Old Jul 17, 2008 | 12:23 PM
Hirnbeiss's Avatar
'99 E430, '05 ML500, '15 GLK350
Don't listen to the man behind the curtain on cooling, your engine will be cooled just fine. My E430 has been running bottomless since I bought it 3 years ago, and runs cold if anything.
If you're a purist and can't live knowing that your baby doesn't wear undies, check with Phil at mercedesshop.
Old Jul 17, 2008 | 05:46 PM
ohlord's Avatar
It's
there for a reason and it is more than just sound proofing,put a temp probe behind the radiator of one with and one without and the engine bay will be hotter in the one without.Also with the 420's pure hatred of moisture I would watch it if you don't like to get stranded with a misfiring 420.
just my two cents,you can ignore it if you want
maybe the guy with 58 posts of "I THINKS" can tell you how to dry off the moisture on a m119 engine when it gets wet.
ohlord
Old Jul 18, 2008 | 12:38 AM
CrossT's Avatar
CLK430
Thanks guys
Looks like a dealer item. I bought this 420 for a 4 month summer car. My vintage 911 is my 8 month car. Last thing I need is electrical problems in the 420 from the deluge splash up from the monsoon rains we get in the summer in Tucson. My steering rack was replaced by the prior owner and - assuming the belly pan covers that, it was not reattached correctly.
todd
97 E420
Old Jul 19, 2008 | 07:44 PM
Musikmann's Avatar
2001 E320 RWD - Brilliant Silver/Ash: 100,000+
Replace your pan. The Mercedes engineers are not morons and would not have designed it that way if it had no useful purpose. The only downside I see is that you might develop an oil leak that the "diaper" catches so you won't know it because there are no drops where you park. That happened to me, and I had a rear main seal leaking that was not discovered until I had the dealer perform an oil consumption test.
Old Jul 20, 2008 | 12:57 AM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
Its there for a reason...
I Have seen several bottom out and take the lower oil pan out
Mercedes makes a STEEL Splash pan that WILL Save the engine if one does a carrier landing with the W210
I Have the STEEL Splash Pans on My W211 W210 and the 209\
My son hit a object on the freeway in the 209 and it Bent the splash pan (Metal)
and That saved the lower oil pan
Install the METAL pan and the HD hardware (Real Bolts..Not sheet metal screws)
Old Jul 22, 2008 | 04:11 PM
EdzBenz's Avatar
W210 W140
Mark,
Where do I get the steel splash pans?
Old Jul 22, 2008 | 05:38 PM
1benzguy's Avatar
+2 I want the steel one...
I lost mine and it Dose raise engine room temp, But the STEEL one sounds nice!!
THX
rk
Old Jul 23, 2008 | 01:07 AM
Originally Posted by EdzBenz
Mark,
I Bought it from Steve @ MBENZNL.com
Its worth the extra cost!
