shift speed
Rather than trust my memory, the re-set procedure should be in your owner's manual.
http://www.mercedesforum.com/m_85449/tm.htm
for an ongoing thread that I posted the reset procedure and all the people that wonder if it works on their model
also a recent post on benzworld.org w210 section on trans reset where we go over the customized procedure for each gear reset it takes more time but if done properly you can adapt each gear one at a time.
other than these have you changed your trans fluid and filter with mb fluid?
I have the special dipsticks if you pm me.Sluugish up shifts in manual shift are often old fluid related.
ohlord
Also some cars that have been driven in a stately manner will go from very docile shift points back to the much firmer higher rpm factory settings,so use you foot accordingly.
some cars wake up more then others in response to the reset.
While you are waiting a few minutes to go for a drive,take that time to check your oil,examine your belt,look around and enjoy day."
ohlord
thank u sir.
ohlord
ohlord
Oh lord for the info. I have not yet changed the trnny oil and filter. I am mechanically inclined but am new to this model and not that well learned on trannys in general. Can I perform this change and if so what is reqired for fluid and tools? you mentioned about a special dipstick?
diys on benzworld.org w210 diy section and mercedesshop.com diy section.
mb fluid only and it will firm up and smooth shifts.
Quicker and I mean much quicker shifts need the new custom valve body sold for about 7bills.You will not be needing that
just do the reset and change the filter and fluid.
