Old 06-15-2015, 02:47 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine Diagnostics
Print Wikipost
Sorting out E320 stalling problem
Old 06-09-2014, 03:06 PM
  #76
kevincdc's Avatar
2004 Mercedes-Benz E-Class
What is MAF?
Originally Posted by BlownV8
Probably a bad MAF. It will get progressively worse with time.
I have 2004 model E320 with same problem:intermittent shutdown at stop idle.
What should I do? Thanks for your help.
Old 06-10-2014, 01:29 PM
  #77
Thomas O'Keeffe's Avatar
2003 Mercedes e320
2003 e320 stalling
Have a 2003 e320 stuttering when idle, rpm dropping,, need to accelerate to keep it going,, stalls occasionally, drives perfectly apart from this issue, always starts,, any ideas?
Old 07-28-2014, 10:13 AM
  #78
bchi205's Avatar
2001 Mercedes Benz E 320
Hey folks im new and I was trying to figure out my problem is on my 2001 e 320 it cranks but no start unless I use starting fluid ounce it cranks the motor idles perfect until I press the gas I have a missfire on the right side of the motor it never goes over 3k rpm and it drops down in rpms as if it wants to cutt off and the check engine light flashes I have new spark plugs, wires, fuel pump, and front o2 sensors but my battery is on its last ride can anyone please help ?????
Old 07-10-2016, 12:00 AM
  #79
ahmedhossame's Avatar
1999 E320
Can you perform a compression test on each cylinder and report the pressure on each cylinder?
Old 07-10-2016, 12:02 AM
  #80
1999 E320
I have a 99 E320 stalling when hot operating temp and then hard start up. I'm going to replace crank position sensor CPS and mass air flow sensor MAF and possibly camshaft position sensor.
If that doesn't fix I will be pointing fingers towards bad ECU. Any other ideas?
Old 07-10-2016, 12:04 AM
  #81
1999 E320
Originally Posted by nelson76
I have a problem on a 1997 E320 it cranks and runs for 20 seconds the most then dies,usually it's more like 2 seconds running,i changed out the cps and it started and ran for almost a minute then just died again,i have fuel pressure and no codes,weird thing is if i step on the gas it instantly dies also i took off the MAF and it looks clean,left the MAF off and started the engine while blocking the intake hose and it ran for as long as i blocked the intake hose,anyone have any ideas?
Have you figured out what went wrong?
Old 07-11-2016, 01:06 PM
  #82
mrbenzes's Avatar
2005 S55, 2002 E430, 2007 CLK350, 1981 380SL
I suggest CPS and possibly throttle position sensor...I had to replace the throttle body on my 2002 e430 and it has ran perfectly since..over a year.
Mike
ahmedhossame (07-11-2016)
Old 07-11-2016, 01:09 PM
  #83
1999 E320
Mike
I have ordered new CPS, MAF and just found that the ECU cooling fan is not working. So I'll need to order a new ECU cooling fan as well.
I'm looking into replacing fuel filter due to the age of the car.
I can see that the throttle position sensor car shut the car off, but my car shuts off when it reaches hot operating temp only.
Old 07-11-2016, 04:05 PM
  #84
fabbrisd1's Avatar
Received 1,099 Likes on 805 Posts
A gaggle of MB's
Please understand - with the "age" of this thread you would be better served in the future to start as new thread.
1) Then your "issue" most likely is to replace CPS sensor - key failure symptom is engine "cuts off" when hot, and long-hard-starting/or-no-start whem warm - then when "cold" no problem.
Replace CPS sensor with genuine Bosch CPS ONLY - and verify type (one-prong vrs 2-prong) by pulling old sensor and looking at connector type before ordering new genuine Bosch sensor.
2) Fuel filter - replace with genuine Bosch or Mann ONLY - the filter has a presure regulation function and other non/quasi-brand fuel filters generally can be poor on this critical function.
3) TPS sensor failure would have entirely different symptoms that you did not seem to have.
Keep the beat !
Old 12-10-2021, 03:42 PM
  #85
thenothingblack's Avatar
2015 C63 Coupe, 1999 E320 Wagon
Hi all!
I see that this thread hasn't been active in a while, but I figured I would ask here before creating a new post.
my E320 has recently started to show signs of what I am hoping is only the Crank Position Sensor starting to wear out.
I bought this E320 for winter driving 2 months ago and twice now (on 2 separate occasions) it has shut off at idle. There is no check engine light, no codes, nothing. It just turns itself off without any warning or sputtering. Started back up both times and runs like normal afterwards.
I would like to fix the issue before it becomes a bigger problem and before it potentially shuts down while moving.
The car has 175k miles and I am not sure if the CPS has ever been changed.
Also twice now the cars RPMs will be a little wonky on startup (fluctuates up and down for a few seconds) and I notice somewhat of a faint burning smell coming from the passenger side, but it goes away quickly. This does not happen in tandem with the shut downs though so I am not sure if they are a related problem.
I feel that my cars symptoms match pretty well with what is described in this thread, but just wanted some second opinions from those who have owned this car longer than I have. Any input is greatly appreciated!
P.S. I do not trust my local dealer as far as I could throw them, they have tried to rip me off more than once
Old 06-03-2022, 09:16 AM
  #86
mhyde71's Avatar
e320
Originally Posted by ohlord
if you diy make sure to read the part added lately about indexing it to the ecu.Very simply done after you replace the crank sensor.
what does this mean?
i been having same problem with my 99 e320....
and so i changed the CPS---it ran little longer, but then died again
did i overlook something when putting it back in? spacer? added part to ECU???
i removed the old and put in the new... i didn't see any spacer, but suppose it could've fallen when took out the old? but there wasn't a new one with the one i got (bosch)
pls thx
Quick Reply: Sorting out E320 stalling problem
