Heavy wear inside tire
Old Nov 15, 2008 | 10:48 AM
MB Enthusiast's Avatar
1997 E 320 - 2000 S500
1997 E320 Goodyear Eagles F1-GS-D3 16" 215/55
Getting usual wear on inside edge of time
What is the most likely problem?
Old Nov 15, 2008 | 12:29 PM
ohlord's Avatar
Front
or rear tires?
Fronts,worn suspension parts,locate which ones repair them,and then get it aligned properly.Rear tires,something is bent.
What does the wear look like?
Old Nov 16, 2008 | 12:12 AM
Deep Wear on inside edge
The tire wore to the point of blowing a belt
Wear on the farthest inside edge
Rear tires
Old Nov 16, 2008 | 12:27 AM
ohlord's Avatar
Extreme
negative camber,since there is no factory adjustment for that issue,it must have a worn bushing or a bent control arm.You need to get it on a lift and either examine it for worn suspension parts bushings etc. or have a good indie mb shop examine it.At the age and miles of your model it is common for bushings to be in pretty sad shape.New ones,new shocks and a good alignment will have it feeling like new.
Old Nov 16, 2008 | 05:13 PM
Estnated Cost
How expensive is this job typically
Old Nov 16, 2008 | 05:19 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
If Nothing is worn out then One can Install the Factory REPAIR bolts to Adjust Camber on the front end
4 bolts needed and a alignment
Old Nov 16, 2008 | 05:30 PM
ohlord's Avatar
His problem
is the rears.So something is worn out or bent.
I think he said rear tires
Old Nov 16, 2008 | 05:49 PM
Ooops
Well If everything looks ok..adjustable camber kit/bars for the rear
I Have seen a few stock 210s with rear camber wear...
Do you haul around four people and a full trunk most of the time?
As alignments are done (Most of the Time) with a empty cabin
Old Nov 19, 2008 | 12:54 PM
lynall's Avatar
E430 Avanrgarde
Mine wore the front tyres down to the canvas and the nearside rear also wore down very quickly.
I am having a 4 wheel track and alignment check, caster and camber this coming Monday.
Not cheap but then neither are tyres
Lynall
Old Nov 19, 2008 | 02:07 PM
Let me know how you make out
Let me know how you make out and if your comfortable the cost as well
