Sagging Headliner 99E320
If anyone has had a similar experience with the headliner, please let me know how you repaired it. Thanks.
I have used 3M Spray glue with decent results
The A/B/C pillars then the front seat belts,dome lights,visors,grab handles should be removed to remove the headliner
Do a search on a copy of WIS it will have all the Information needed to do the job the correct way
I would imagine the WIS has a recommendation for the correct product and it would probably be available from the dealer. And as Mark says the correct procedure.
If you can't access that information, you might go to the 3M website or a supplier like www.mcmaster.com (McMaster Carr) for application information.
Good luck.
www.alldatadiy.com has the wis.
But Ray's link to his pdf might give you some free help
http://www.benzworld.org/forums/w210...eadliners.html
