Oil soaked Sparkplugs
Old Feb 9, 2009 | 10:14 AM
Karachite's Avatar
2001 E320
Replaced plugs on e320 75K- noticed oil on the sparkplug threads. This is of concern how much????
Old Feb 9, 2009 | 01:13 PM
4matic's Avatar
04 S430 4Matic/03 Ml 320/ 98' E320 4matic/ 73' slc 450/ 05 cherokee
Post
uh...
prolly not good...
prolly not good at all...
Old Feb 9, 2009 | 02:34 PM
JeffreyP's Avatar
Improperly torqued or years of driving vibration would cause plugs to be a little loose. Oil will find it way up there from the cylinder. Nothing to be concerned about, just make sure you torque the new plugs properly.
JP
Old Feb 9, 2009 | 06:55 PM
ejsheltra's Avatar
2003 S210 3.8L Brabus wagon
Have you checked for oil consumption? If your car is burning oil it could be a broken ring or valve seal. But only if you are consuming oil. MB motors will consume some but certainly not more than 1 quart per oil change. Plugs in normal condition should be dry and the electrode clean from any deposit. If there are deposits on or near the electrode you are consuming oil and should have the motor checked. W124s would average a quart every 3-4000 miles.
Old Feb 10, 2009 | 12:23 AM
ohlord's Avatar
Someone
may have torqued them improperly in the past.What year E320?
Clean the threads and install and torque the plugs properly.
There is only 1 way for oil to migrate up the threads and that would be a loose under torqued plug.
Do it correctly and it won't be an issue
Old Feb 10, 2009 | 10:14 AM
Karachite's Avatar
2001 E320
Its a 2001 @75K miles with no oil consumption. I have torqued the new plugs appropreatly, will check them later after 1K miles.
Thanks you all!
Old Feb 10, 2009 | 11:57 AM
ejsheltra's Avatar
Thanks you all!
That's a relief. Sounds like Oh Lord is on it with proper retorqueing and cleaning. Welcome to the forum.
Old Feb 10, 2009 | 01:12 PM
ohlord's Avatar
If
you tq'd them properly,just leave them to a happy life.No need to check them.No misfires,no p0300 codes,no oil consumption ,No problems
Tell all the other members how good it felt knowing that you saved about 500 bucks by doing it yourself v.s. the shop
Time to change your transmission fluid next.MB spec fluid only.Easy DIY if you follow directions.
Old Feb 12, 2009 | 10:38 AM
JeffreyP's Avatar
ohlord, you're such a
Just kidding.
