Pepped it up a little
Old Mar 19, 2009 | 01:43 PM
Air Marshall Eldritch's Avatar
John Deere
Having reached 121k miles on my original spark plugs, I figured it might be time for a change.
Had TVT Design replace the OEM plugs with NGK Iridium, and while doing so also swapped out the wires for Magnecors.
The car immediately felt more responsive, more freely revving, and my fuel economy improved a fair bit.
If you're looking to get a little pep, I recommend this change.
Old Mar 19, 2009 | 03:49 PM
BENZITCH's Avatar
1991 560SEC Teal 1989 420SEL Ice Blue 1984 500SEC White
Couldn't you have waited another 20k miles or so, and than got the oil changed at the same time! LOL
Old Mar 19, 2009 | 06:05 PM
John Deere
Heck no, that would be 50k, not 20k!
Old Mar 20, 2009 | 07:28 AM
ohlord's Avatar
NGK 7090
plats would have done the same thing.
New wires were not needed,when properly removed with the 17 mm boot tool,they never wear out.Magcores will lead to misfires,so if you start seeing obd2 codes for p0300 you will hope you had hung onto the oem wires that last forever.
At 121k miles,it is no wonder it feels more responsive.
The oem plugs were most likely down to the nub and gapped worn to .045 instead of oe .039
$38 delivered from me for the 17mm boot tool and 2.89 each for the plugs at any local parts store and 2 hours of your time on a sat. morning and you coulda had it done by yourself,for under 100 bucks
What did the indie charge?
Old Mar 20, 2009 | 10:51 AM
John Deere
The plugs were worn down pretty much all the way.
I'm not sure why you are claiming they will cause misfires.
The labor was almost nothing. We had to wait almost two hours for the computer files to download at the same time (different project). And frankly, that is one job I'd rather not do. Those plugs are buried in there pretty good, not to mention being frozen after 10 years.
Old Mar 20, 2009 | 12:13 PM
BENZITCH's Avatar
I know the other project.
Old Mar 20, 2009 | 12:56 PM
John Deere
Ohlord, I checked around and learned that the old blue magnecors had problems slipping off, but the new red ones have no issues in the 15-20 cars he put them in, including his own track racer.
Old Mar 20, 2009 | 05:46 PM
rennwerkes's Avatar
2001 E55, 2002 ML55, 2002 SL500, 2003 CLK55
I've got to agree with ohlord on this one.
Had a Porsche and used Magnecor's that everyone talked so highly about.
Had a friend do some work on the Porsche and he said the Magnecor's were leaking voltage all over and looked like a Christmas tree.
I also have to agree that the factory wires sets are hard to beat. Even on BMW's the OEM wire sets are very nicely made with high quality parts. Although I don't know why Mercedes wanted to use metal on the plugs rather than silicone.
Old Mar 20, 2009 | 06:08 PM
ohlord's Avatar
Race set
wires are for race cars.I race also and there are better wires than mags.
However for the street and the mb ignition the oem wires can't be beat.They do the job,they match the coil output and they last till the end of time.Unless you yank on them instead of using the offset boot tool.
With that tool and 2 hours I have talked girls through the plug change on a C320 .Now that is a tight fit and they managed.Plus the dealer wanted 800 bucks,so they were very happy
Old Mar 23, 2009 | 06:07 PM
John Deere
What color were they?
I have had no problems thus far. In fact, I am spanking tractor trailers left and right.
Old Mar 23, 2009 | 06:38 PM
rennwerkes's Avatar
It was a while ago so can't remember what color.
But I know they had less than 10k on them.
