2001 E430 Sport Front Catalytic Converter
Old May 13, 2009 | 09:14 AM
crypto430's Avatar
2001 E430 Sport
My CEL light came on and the shop said it's my front passenger catalytic converter. I've researched cats here and found that people have success with the Magnaflow 53005. However, I'm not clear if this will work on the front/primary or only the secondary? Can someone help me out?
Thanks,
Bob
Old May 15, 2009 | 01:05 PM
Max Hughes's Avatar
You mean the pre-cats? The Magnaflow 53005 is a full size cat, the pre-cats are pretty tiny right? If I where you I'd have a shop take them off, there's no harm done, it sounds better and you'll still pass emissions.
Old May 15, 2009 | 04:12 PM
crypto430's Avatar
2001 E430 Sport
Yes..the pre cats
I'd like to purchase a magflow and have it spliced in. I don't know what size to order. That's why I'm asking if anyone has had a magnaflow spliced in for pre cat.
Old May 16, 2009 | 01:02 AM
j944's Avatar
2002 CLK430
I havent used Magnaflow but had both changed using Eastern universals and havent had any issue's.
Installation costs me $130 each......Far less than the stealership
Old May 19, 2009 | 10:15 AM
crypto430's Avatar
2001 E430 Sport
What model number for eastern did you use?. I checked and they said they don't have one rated for an E430.
Old May 19, 2009 | 10:06 PM
j944's Avatar
2002 CLK430
I am not certain. The rcpt says 2/14 CAT L10...I hope this helps
Old Aug 30, 2009 | 05:11 AM
kevinGTB1's Avatar
F150
Hello there, is magnaflow catalytic converter really good?
Old Aug 30, 2009 | 05:55 AM
kevinGTB1's Avatar
F150
Im new for this forum
Old Aug 30, 2009 | 01:39 PM
fosmith's Avatar
2001 E430, Obsidian Black w. Ash/Orion Grey, 195,000 mi.
Thanks,
Bob
Bob, the Magnaflow 53005 is a replacement for the rear cat only. You may have to get a direct fit assembly to replace the front. They're about $400 unless you live in California where the only legal option is to get the part at the Mercedes dealer for over $1000. The advantage of a direct fit assembly is that it's a pretty easy diy.
Fred
Old Aug 30, 2009 | 06:07 PM
kevinGTB1's Avatar
F150
Anyone knows about magnaflow catalytic converter if it is pretty good? thanks.
Old Aug 30, 2009 | 11:15 PM
ohlord's Avatar
Yes it is good
if as above stated it is the big cats under the middle of the car that are rattling like a can of rocks. Eastern cats google them or racepages.com are also good universal cats unless as stated you live in Ca.
In that case magnaflow has production ready in about 10 weeks CARB calif approved splice in cat for the secondary cat application. No prices avail yet.
Old Sep 1, 2009 | 01:44 PM
kevinGTB1's Avatar
F150
Thanks Ohlord
One more thing, I do some research and queries regarding this issue so I tried it here Magnaflow Catalytic Converter, anyone tried it here if they provide good services? Thanks in advance.
