Wiper Fluid Leak
Old May 29, 2009 | 09:54 PM
E420-97's Avatar
1997 E420
Question Wiper Fluid Leak
I ran out of windshield wiper fluid so I refilled it. When I tried using the wiper fluid, only a little came out on the windshield and I found that most of it had drained out of the container.
Does anyone have a diy's or a way I can check where the leak is and fix it?
Old May 30, 2009 | 03:50 PM
Lancelot's Avatar
'01 W210 E320 CDI
There is about 5 Liters of fluid in that reservoir. If it all leaked out there's obviously a very large and visible leak. Refill it and check visually, it can be a hoseclamp, or a cracked hose or reservoir, or the lid is leaking...
Old Jun 6, 2009 | 10:03 AM
E420-97's Avatar
1997 E420
windshield washer fluid leak
thank you. I will try following the hose. hopefully it's something simple.
Old Jun 6, 2009 | 12:50 PM
TMAllison's Avatar
09' E320
There is a rubber grommet type seal that the pump is inserted through. Pump is on the exterior of the reservoir at the bottom front. Or, clean the emitters with a fine wire......
Old Jun 6, 2009 | 01:33 PM
E420-97's Avatar
1997 E420
Thank you. I'll try it. Does anyone have a diy with pictures?
from a brave novice.
Old Jun 6, 2009 | 05:16 PM
TMAllison's Avatar
09' E320
See #155 & 158.
http://www.detali.ru/cat/oem_mb2.asp...SGR=030&SGN=01
Old Jun 30, 2009 | 01:45 PM
E420-97's Avatar
1997 E420
THANK YOU THANK YOU!
My windshield wipers now work again without replacing parts! I appreciate everyone's input.
Old Jun 30, 2009 | 03:01 PM
gatonls's Avatar
97 E320, 04 C230K, 06 R500
Well, what did you do to fix it? Or did it fix itself?
