722.6 transfluid change Question...
be sure to follow the diy work clean no linty rags no dust no dirt and fill to level slowly go shy of full amount and bring it up to proper level slowly.
Do not over fill.
The OP owns a diesel and therefore your advice wasnt appropriate. My old cap "snapped" down in place just like its replacement does; on a diesel at least, that is no guarantee it is going to stay there for the long term.
has everyone a desire to be appropriate all the time?
install a thicker o ring and it won't come off and you can check fluid level and condition any old time you feel like it and not be indebted to the dealer for locking tabs which you don't need.
to each his own though
You may already have this, but you also need a drain plug washer for the oil pan. That one is made of copper (not aluminum as the TQ drain plug washer).
Work clean. No dust or lint. Check the pan for flatness and torque properly.
Refill slowly once you get close to the volume you removed.
Have fun.
