Antifreeze
Check that your fan is operating properly and you don;t have any other issues besides low coolant. The stuff went someplace. You might want to have a pressure test done to find out where it went.
Good luck.
When I took the coulant cap off, the level looked like it was down. Is there a mark on the reservoir where the coulant should be up to? I have added 1/2 liter of 50/50 water and Zerex.I can't tell if this enough.
Good luck.
I still would suspect your main fan, because your car shouldn't be getting that hot (I had a 104 for several years in Alabama and Houston, and have had the M113 for 2 years in FL), and we know you had enough coolant (you could see some in the tank, there was no steam, and you didn't have a warning light). The viscous clutch should be engaging by 92C, and you should be able to hear a lot of whooshing noise then from the fan, which is plenty capable of keeping your car cool. Having one of 2 aux fans out, OTOH, I would be very surprised if that's the only culprit.
The aux fan belt is easy just remove the whole fan assembly shroud and all and the belt is an easy push and wiggle fit job.
Lynall
