i got a cruise control problem
Old Sep 11, 2009 | 01:35 PM
roach_juts's Avatar
2000 e430( w210),1979 240D (w123), 1992 300e(w124), 1990 mitsubishi galant VR4
hello
my 2000 e430 cruise controls stop working, it wont engage
i tried to engage or accel it just wont hold....
any suggestions ???
i have a leak on 1 of my vacuum pump at the rear driverside door.. the lock wont unluck if i unluck the door .... is that culprit why my cruise control not working ???
Old Sep 11, 2009 | 02:03 PM
ohlord's Avatar
CC
vacuum is controlled off of engine vacuum not PSE vacuum that controls doors etc.
Look for a broken engine vac line and if it happened all of a sudden check all your tire presures a very low tire can prevent use,
lastly cc module could have failed or S40 cc switch on steering hub . Sds scan will point that out.
Old Sep 12, 2009 | 03:29 AM
roach_juts's Avatar
thanks .. ill check all those possible vacuum leaks. and ill have the car diagnose tom
Old Sep 12, 2009 | 01:25 PM
Hirnbeiss's Avatar
'99 E430, '05 ML500, '15 GLK350
Does the cruise engage when you push it down (decel position)?
