W210, E 280, 1998 Engine cranks but does not start
Old Sep 25, 2009 | 07:22 PM
sammouhali's Avatar
E280 1998
Hi evryone,
I have the a problem that might be the CPS, but with some additional symptoms; car is not starting + computer display is black + saloon rear light is off.
If it is the CPS, please share some photos on where it is located exactly
I was driving the car this morning and it was perfect. came back and parked the car; 3 hours later it is not starting; cranking very well but no start
The computer display was initially on, but after trying to start it several times, to no hope of course, computer display went off.
tried to disconnect the battery, with the key off, then I came to realize that the saloon rear light is off. Odd huh Disconnected the battery though, both positive and earthing, reconnected after few minutes... still the same.
Seems I am about to spend some real money
You help and any input is realy appreciated.
Thanks a lot.<!-- google_ad_section_end -->
Old Sep 25, 2009 | 10:01 PM
ohlord's Avatar
Probably not the cps with those other issues.
Check all the fuses. You may have spark but no fuel. So look for that fuse first.
Fuse chart should be by the battery under the seat.
Don't go to the dealer if you can't solve it. Call around to mb indie shops and find one that uses an sds machine and they can diagnose it.
Any check engine light?
Old Sep 25, 2009 | 11:14 PM
Perrier's Avatar
2001 E240
Does the techometer needle move while cranking?
Old Sep 26, 2009 | 07:52 AM
sammouhali's Avatar
E280 1998
WOW CPS location is extremely tight... at least for me...
Guys,
I oppened my hood today and tried reaching to the CPS; for me... there is no way I can reach it. even after removing thhe plastic cover, I can hardly see the CPS but cann't even see the bolt.
Anyway I got my beauty loaded on a recovery truck to one of the local mercedes mechanics, who is having lunch now. I'll be heading his way again within 15 minutes.
Any ideas on how to convince him that it is the CPS before he costs me alot by changing the fuel pump, and of course the filter, then telling me "oh no, the fault is still there"
Thanks guys.
Old Sep 26, 2009 | 09:16 AM
ohlord's Avatar
If you
need to get at the cps you need to use the hood release that is on the side of the hinge up by the base of the window. that allows the hood to go all the way up.
You won't need to convince a good mb tech of anything he will if good, diagnose it and fix it properly.You are in his hands now. Just let him fix it.
Old Sep 26, 2009 | 09:34 AM
sammouhali's Avatar
E280 1998
I have already done that
Hi,
First of all, your quick responses is realy outstanding; Thanks a lot.
I have already released the hood to the maximum, read this trick before. But I found it to hard for me to get. Remember, I live in Dubai, Temperature here is 45 degree C.
Anyway, I just came back from the MB tech shop and he has confirmed that it is the fuel pump and that he has already checked the sensor and it is ok. The original MB fuel pump is 163 USD and the labor charge is 32 USD. Fine so far.
Once he is done I'll see what he will do with the blacked out display.
By the way, being too stupid, I have turned around the fuse chart and found out that the English version of the fuse chart was just on the other side
I will let you know this evening once I come back from the tech shop.
Thanks again.
<!-- / message --><!-- sig -->
Old Sep 26, 2009 | 02:41 PM
sammouhali's Avatar
E280 1998
Haven't noticed
Hi,
Thank you for your response, actually I haven't checked, the car is still with the local MB tech. The problem has been fixed, by replacing the fuel pump, my car has now done 249,000 Km and I have replaced the fuel pump only once before 4 or may be 5 years.
However, I went to collect the car, but the display is still dark and the rear left window is not working. Not only the display is down, but also the tachometer backlight and everything. He said it might be fuses or something; I suggested to leave it for him to check it further and check back on him tomorrow after work.
Thanks a lot for your support and Rob as well.
I will keep you posted tomorrow on the progress.
Thanks guys.
Old Sep 26, 2009 | 02:57 PM
sammouhali's Avatar
E280 1998
Problem partially fixed; but display is still out
As stated above, the car has now started, but display is still black and rear left window will not work. Do you think it will be fuses, or may I fried something while trying to start it yesterday.
Thanks Rob
Old Sep 27, 2009 | 02:29 AM
Perrier's Avatar
2001 E240
sammouhali - do you have the problem of start delay (from excessive cranking) before you changed your fuel pump.....or it is happening all of a sudden car just cranks and does not start?
Old Sep 27, 2009 | 03:52 AM
sammouhali's Avatar
E280 1998
Yes I had it
Yes, I had the problem of delayed starting before replacing the fuel pump. what does that mean?
Thanks.
Old Sep 27, 2009 | 03:58 AM
sammouhali's Avatar
E280 1998
What about the black display, any ideas?!
Old Sep 27, 2009 | 06:40 AM
ohlord's Avatar
Fuse
and whom is this Rob you speak of?
ohlord
Old Sep 27, 2009 | 07:11 AM
sammouhali's Avatar
E280 1998
ohlord
You got me confused
Quote
" Hi,,
Good luck friend.
We have other members in the UAE
You should locate them.
Rob "
unquote,
this is the Rob I'm speaking of.
Excuse me if you are serious. But if you're joking you definitely got me<!-- / message --><!-- sig -->
Old Sep 27, 2009 | 09:02 AM
Perrier's Avatar
2001 E240
Thanks.
For how long does this delayed starting last before finally the car does not start?
Old Sep 27, 2009 | 11:38 AM
sammouhali's Avatar
E280 1998
Problem solved
Guys,<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p>
Thank you all very much; problem solved as follows:<o:p></o:p>
<o:p></o:p>
1. Cranking but not starting: Replaced fuel pump<o:p></o:p>
<o:p></o:p>
2. Instrument cluster black out: cables connections were fixed as cranking too much, trying to start it, caused the wired connection to malfunction<o:p></o:p>
<o:p></o:p>
3. Left rear window: issue is not relevant. Weather here is too hot and I haven't used this window for long time; got stuck due to the humid dusty weather. Removed the window m/c, cleaned and reinstalled and working fine now.<o:p></o:p>
<o:p></o:p>
Thank you all.<o:p></o:p>
<o:p></o:p>
Tip:<o:p></o:p>
Next time my car cranks without starting I will never keep cranking for long long and several times, destroying other stuff on my beauty.<o:p></o:p>
