'Check Engine' light by missing a gas cap?
Old Sep 30, 2009 | 10:51 PM
piusthedrgolf's Avatar
2006 E350 & 2011 ML350
Hi all,
I wonder if the 'Check Engine' light can be ON by missing a gas cap.
The light just got ON after the gas cap has been broken.
oh.. My car is...
2002 E320 4matic Wagon
Old Sep 30, 2009 | 10:53 PM
C43AMG's Avatar
Veteran: Army
98 Black C43 , 12’ ML 350 Blutec
Yes !
Old Sep 30, 2009 | 10:55 PM
Originally Posted by C43AMG
Yes !
How it gets turn OFF?
I just got a new gas cap and replaced it. But the light is still ON.
Old Oct 1, 2009 | 12:04 AM
FraKctured's Avatar
W203-4M W163
It's probably the oxygen sensor, get that checked. Not a lot of money to get fixed, and fairly common in that era.
If it's the Oxygen sensor, it is not critical to get it fixed, so don't fret about it.
Old Oct 1, 2009 | 05:03 AM
ohlord's Avatar
Don't take advice from someone
that does not know of what they speak.
If you got a new cap from the dealer and not a cheap cap from some auto store the light will go off after a few drive cycles where the system tests itself and sees no more errors in the emissions system.
If it were the o2 sensor which it is not.You would need to get it fixed it is one of the most important parts of the system both in emissions,fuel economy and how the car runs.I don't know about you guys sometimes Not important???? Like not important in that it can cause misfires and ruin a $500 cat converter,you mean that not important?
Old Oct 1, 2009 | 09:27 AM
Dang.. As you suspected it, I did purchased and replaced with a cheap gas cap for the model, not from MB dealer. Since I'd replaced it a day ago, I will see if the 'Check Engine' light goes 'OFF'. if it doesn't, as you mentioned, I will get a new cap from dealer. Thank you.
Old Oct 1, 2009 | 05:16 PM
Peter Guenther's Avatar
92 500sel/01 320e wag
If the cap is not, on or loose, you will get the check light, its somewhere in the owners manual.
Old Oct 5, 2009 | 09:19 AM
FraKctured's Avatar
W203-4M W163
Easy does it Ohlord...I meant "don't fret about it" as in "the engine won't explode if you don't rush in tomorrow and get it fixed." Yes, of course, get it fixed, it doesn't cost that much anyway, but it won't kill the car to do it when you get around to it. Roll eyes, rolf rolf, rolf eyes, roll roll
Old Oct 6, 2009 | 10:51 AM
Now the check engine light is gone, even with a cheap gas cap from eBay. Thanks guys~
