Shift stick loose...
Old Oct 2, 2009 | 01:06 PM
daSong's Avatar
2001 W210 E320
Hey guys, has anyone else experienced their shifter feeling loose?
The other day, I shifted from park to drive and the stick just felt very loose. It had always felt nice and tight. It's also loose going back up to Reverse and park. The car runs fine otherwise.
Is this a sign of some problem? Should I get the transmission checked out?
Has anyone else had this happen to them? If so, what fixed it?
Thanks yall...
Old Oct 2, 2009 | 04:43 PM
dylokjai's Avatar
00_e430_sport
Thanks yall...
shift knob or shifter itself?
Old Oct 2, 2009 | 04:56 PM
Franasia's Avatar
2000 E 320S4 210.282 4Matic Estate
Shifter Linkage Bushing
Look at the stickies at benzworld.org. An easy and cheap fix. Parts about $3.00.
Cheers
Old Oct 2, 2009 | 09:44 PM
TMAllison's Avatar
09' E320
Shifter bushing; located up high in the left hand side of the trans tunnel. Need small hands or 12" needle nose to reach. Bushing is green usually.
Old Oct 31, 2009 | 01:43 PM
J2cruz's Avatar
1997 E320
Thumbs up Bushing
What is the part called and or what is the part number...thanks
Old Oct 31, 2009 | 03:15 PM
Franasia's Avatar
Read my previous
posting. Benzworld.org.
Old Nov 1, 2009 | 03:49 PM
99210's Avatar
1999 e320
shifter bushing on shift rod//at shifter side or trans side//
Old Nov 16, 2009 | 01:19 PM
J2cruz's Avatar
1997 E320
shifter bushing
Do i have to go under the car or NO?
Old Nov 16, 2009 | 01:51 PM
ohlord's Avatar
Yes
Old Dec 28, 2009 | 01:10 PM
J2cruz's Avatar
1997 E320
Originally Posted by ohlord
Repalced bushing and locks and now i am having problem on starting. it long time to start, have to play around with the shifter and then when it start. and when put on gear it wont go and have to play it again until you feel it kicks and then will go...i don't know what to do now..is it a transmission problem or what, please help.....
Old Dec 28, 2009 | 01:46 PM
MBtech1098's Avatar
10 speed bicycle
You may need to re-adjust your shift linkage. Done from the bottom.
Old Dec 28, 2009 | 09:40 PM
J2cruz's Avatar
1997 E320
how do you do that? and which one do i need to adjust? can you give me specific please...thanks
Old Dec 30, 2009 | 07:17 PM
MBtech1098's Avatar
10 speed bicycle
Raise the vehicle, have someone hold the shifter in drive, when looking up at the shift rod near where the shifter is from the bottom you'll see a torx or allen, loosen that push the trans into drive(lever on trans all the way forward) and tighten...tada!
Old Jan 4, 2010 | 03:12 PM
J2cruz's Avatar
1997 E320
T H A N K S
