spark plugs
2001 Mercedes wagon E320
spark plugs
When do they need to be change or when should they. Do I need a special tool? I have a 2001 E320 wagon,and they are difficult to get to.
Is there something I should know?
1 Post
2000 E 320S4 210.282 4Matic Estate
They need replacing
every 100000 miles. There is one key tool needed: a special boot puller spanner (you can get from ohlord). The rest are simple tools such as a 3/8 ratchet with a couple of extensions, and a slim 16 mm (5/8") spark plug socket with rubber insert. Torque value is 28Nm. Some people do it very with torque wrench, some don't. I consider it important to torque them to spec. Hope it helps.
Cheers
Cheers
1 Post
greyvan,
Sorry, did not realize you're a new member
- welcome to the forum then.
I have a 4Matic wagon also.
ohlord is a forum member. You can also find some excellent stickies and DIYs here:
http://www.benzworld.org/forums/w210...ain-drive.html
Cheers
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
Cheers
2001 E320 4matic sedan
Spark plugs every five years
or 100,000 miles--it's in the owner's manual.
Use Bosch or NGK 7090 plugs with the single side electrode--do not use multi-tip or any other snake-oil plugs, according to ohlord.
1 Post
Bosch 7422
is the correct Platinum plug for the M112 engine. Stay away away from the other Bosch Platinum types. There have been bad reports by other members in the past.
Cheers
Cheers
spark plugs
NGK 7090 single-side electrode platinum plug.
.039 gap, use no anti-seize, they are bivalent plated.
$3 each, and they'll last 100k.
Or Bosch 7422, about 4 bucks.
You'll be needing the 17mm Mercedes boot tool. You can get one of these from Ohlord.
You are
well past ready. The car is 8 years old and plugs were due to be changed 3 years ago.
Pm me for info
Pm me for info
Hi
I pulled a couple of plugs and they look just fine. My guess is someone changed them not to long ago, I got the wagon with 109k mi on it. I do have a pretty noticeable miss at idle, not really sure when moving along. What's a go way to locate the Problem? Is it common?
Help
Help
Looks don't tell the story
or at least the whole story.
Check the gaps. They could look fine and gap at 44tho.
1mm
or .039tho in.
Toss in a can of seafoam brand injector cleaner into a half filled tank of fuel and drive till near empty then fill as normal with premium fuel.Never top off the tank.
Spark plug tool
Pm sent
and it includes free phone support to talk you through the procedure.![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
That is if you need help.Extra tips and such make the job quicker and fewer busted knuckles
![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
