HELP! Guage Cluster Dilemma
You can get them vin range numbered and they will work.
The tank sender is different and I don't think reversing polarity is going to take care of it.
If you try all that will happen is it will work or it will fry.
Used vin matched w210 cluster will work it will just show the donor car miles.
Did you try the pixel fix solution?
Works in a lot of cases when done properly has saved or restored a lot of pixel dead clusters.
