rim and tire? Help before I do something stupid
Old Feb 10, 2010 | 10:45 PM
StevieBenz's Avatar
85 300D(the trusted), 97 E420(the ticketed)
hello everyone. I just got a 97 e420 after driving a 84 300d for the last 10 years. Love the e420 but the stock 16s look so small on the car. Does anyone know if 245/45/18 on 2006 s600 amg rims will fit. I need new tires and I can get these real cheap but I'm worried they'll rub and make my car look like 4x4.
Old Feb 10, 2010 | 11:19 PM
ejsheltra's Avatar
2003 S210 3.8L Brabus wagon
S class used 14mm bolts and seats and E class uses 12mm bolts and seats. You will need special 14mm bolts with 12mm threads available through RAD I believe. Check the ET. The Eclass uses 30 to 35ET.
Old Feb 10, 2010 | 11:30 PM
StevieBenz's Avatar
I'm pretty sure et32 was stamped on the rims
Old Feb 11, 2010 | 12:09 AM
BordeauxW210's Avatar
W210 E430
Those are some big tires to run up front. I would test fit first before finalizing any deal.
Old Feb 11, 2010 | 12:10 AM
RichardM98's Avatar
98 Brilliant Silver E320 Wagon
If you do a search on 'AMG wheels' you'll find a lot of posts with your question.
Not many problems with upgrading to 17" because it was a factory upgrade when the car was new. 18" and above you need to do your homework. Ride will suffer but maybe that's not a priority for you. Also, be cautious of fakes as it's pretty easy to change a stock MB wheel into a AMG looking one. Most MB wheels have part numbers on inside of spokes.
Good luck.
Old Feb 11, 2010 | 12:29 AM
StevieBenz's Avatar
I tried searching other post for answers and the closest I got was people saying they run 245/40/18 but nothing about 245/45/18 (in front at least)
I don't care too much about the ride I work less then 3 miles from home. The #s on the spokes was one of the first things I checked, there true amg. Thank you for your concern there is a lot of knockoff mb wheels out there.
Old Feb 11, 2010 | 01:36 AM
raymond g-'s Avatar
99 E320
245/45 'will' work but only if a number of other factors and changes are
made (or, at least be ready to modify).
if the car is otherwise left unaltered, your car may be okay but upon hard
compression the tire may rub.
if you intend to lower your suspension, the odds of the tire rubbing increases.
if you have cruise control, and running staggered front/rear, this mismatch
will cause the cruise to disengage.
if you're planning to run 245/45 all the way around, your odo and speedo
will read lower and slower than it actually is....by about 5%
Old Feb 11, 2010 | 12:07 PM
Red66GT's Avatar
2008 S63 AMG Designo Edition
I have staggered wheels on my car and my cruise works fine?
Old Feb 11, 2010 | 03:45 PM
raymond g-'s Avatar
99 E320
my reference was based on the OP's partial information. he only identified
front rims with 245/45, somewhat implying that the rear tire size may be
different. since it's unlikely he would have staggered with 245/45 all the
way around, the likelihood of mismatch, ergo cruise control malfunction,
increases.
you didn't post the tire sizes for your staggered configuration, so I have no
opinion on the suitability of your set up.
I have staggered on mine and the cruise feature is fine. so the devil is in
the details, ie the rolling distances between front and rear tires must be
within the narrow window of acceptability
Old Feb 11, 2010 | 06:19 PM
Red66GT's Avatar
Ah....gotcha. Thanks for clarifying!
Old Feb 13, 2010 | 10:27 AM
StevieBenz's Avatar
OK so I passed on the 18s to much curb rash. Does anyone know if I put 17s from a 2001 clk 430 amg with 225/45 in the front and 245/40 in the rear if that give me any problems with my speed or cruise?
Old Feb 13, 2010 | 01:00 PM
raymond g-'s Avatar
99 E320
http://www.miata.net/garage/tirecalc.html
plug in both tire sizes. keep the differential between them to within 2% and
you should be fine
Old Feb 13, 2010 | 05:31 PM
W210 E430
Make sure you check the wheel offsets too.
Old Feb 14, 2010 | 12:57 AM
raymond g-'s Avatar
99 E320
forgot to mention to plug OEM tire size as well, then each of your targetted
tires. this will give you an idea how much your odo/speedo will be off with
the tire swap.
