eBay HID kit is awsome..!
Old Mar 18, 2010 | 11:39 AM
Benzo 003's Avatar
2008 ML350 4matic
As pjjoh1 stated....the k is for color, not brightness. 12000k is actually less bright than 6000k. 12000k would be alot more blue/purple....5000k is considered "pure white" and is usually the brightest.
I have a 6000k kit that appears almost silver, if silver could be a color of light. They are not white, but not blue either.
xenithxenons.com just released a HID kit that will actually focus the beam more like a factory xenon lens instead of a "generic" kit.
As a member of law enforcement, when everyone says that HIDs are illegal, at least in Illinois, the only thing applicable is color. Only emergency vehicle can display illuminated blue lights.
Brightness can only be enforced when it applies to failing to dim the headlights from hi-beam to low within 500 feet of an oncoming vehicle.
Poorly aimed / bright low beam lights are not enforcible unless they are "blue".
I have not seen "blue" tested in court.
Old Mar 18, 2010 | 11:53 AM
E92-Lighting's Avatar
Former Vendor of MBWorld
BBS LM's 18's + Kics
you get what you pay for, usually speaking higher kelvin=less output, i would recommend MTEC 6k bulbs instead for brighter performance
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
Old Mar 18, 2010 | 04:09 PM
vadimkag's Avatar
E320 4matic wagon
Im happy with my upgrade specialy for this price.
Old Mar 19, 2010 | 05:38 AM
Semikolon's Avatar
2001 E220T CDI Avantgarde, 2002 E55T AMG
Oncoming traffic will not be happy with it..
Old Mar 19, 2010 | 03:05 PM
vadimkag's Avatar
E320 4matic wagon
Trust me it's not that bright
Old Mar 19, 2010 | 04:34 PM
Semikolon's Avatar
But there is a lot of glare from it.
Old Mar 19, 2010 | 05:51 PM
  #32
Dave1965's Avatar
2001 E55, 2022 Corolla Hatchback XSE, 2024 RAV4 LE, 2024 F150 XL SuperCrew 4x2 3.5 Ecoboost
Originally Posted by vadimkag
Thats why you lower the heads lights a little if you want. But I dont care... Like I sad for $44 its realy good upgrade.
When buying a kit you can coose which ones you want they have from 3k up to 30k but I like 12k color.
Did this trigger a bulb warning in your dashboard?
Old Mar 19, 2010 | 06:53 PM
  #33
vadimkag's Avatar
E320 4matic wagon
I thought it would but nop, nothing.
Old Mar 20, 2010 | 05:42 PM
  #34
BigBoss's Avatar
2002 Mercedes Benz E320
I received mine today. I guess I have to disconnect the battery but I do not have a radio code...
Old Mar 20, 2010 | 05:54 PM
  #35
Benzo 003's Avatar
2008 ML350 4matic
you really dont need to disconnect the battery, just dont turn it on until ALL connections are made.
Old Mar 20, 2010 | 06:45 PM
  #36
BigBoss's Avatar
Turn on the lights or the car?
Damn there is a lot of wiring. I'm a bit confused on how to start.
Old Mar 20, 2010 | 08:37 PM
  #37
vadimkag's Avatar
E320 4matic wagon
On mine there where only two wires that plag and play...
Old Mar 20, 2010 | 08:39 PM
  #38
vadimkag's Avatar
E320 4matic wagon
dont have to disconect battary just make sure your lights are off and there is red wire and black one, so black goes to yellow and red to black in your car. If your kit like mine...
Old Mar 20, 2010 | 09:02 PM
  #39
BigBoss's Avatar
I also got the error code eliminators with mine since its '02+.
Old Mar 20, 2010 | 09:10 PM
  #40
h0rn3t920's Avatar
97 E420 W210, 95 Volvo 850 Turbo Wagon
If your looking for good HID's go to Stealthauto.com they have really good stuff and they are cheap! I have their 8k bulbs in my car and they look like 6k from up close but far away they look so great haha the PERFECT color really. Looks alot like 8k but you get 6k light quality!
Old Mar 20, 2010 | 10:16 PM
  #41
vadimkag's Avatar
E320 4matic wagon
oh mine is 98. you might have to order a relay kit from same guy you bought your hid's.
Old Mar 21, 2010 | 07:30 PM
  #42
BigBoss's Avatar
I still haven't figured out how to install it. I get the general idea of it but I don't want to screw something up. And the instructions provided are pretty crappy.
Old Mar 21, 2010 | 09:14 PM
  #43
vadimkag's Avatar
E320 4matic wagon
well sicks for you... im sure its easy fix
Old Mar 22, 2010 | 08:35 AM
  #44
jgananE320's Avatar
2002 E320
BigBoss... u got urs form ddmtuning didnt u? heres a link on installation.
http://ddmtuning.com/support/index.p...1&pcid=0&nav=0
here is another if u have bi-xenons...
https://mbworld.org/forums/e-class-w...tor-retro.html
dont forget the in-line fuse.
Old Mar 22, 2010 | 10:39 AM
  #45
SLOPESTAR's Avatar
99' E320 4MATIC ESTATE / 92' 190E 2.6
Vadimkag.
Off topic but your speling n gramr r baad
Old Mar 22, 2010 | 11:53 AM
  #46
ohlord's Avatar
Yikes
vadimkag is from Washington
I thought I had all those guys trained
He must be 18-21 and slipped through the poser crack
Love the post about aiming the headlights down. See so many Honda **** rockets up here with the HL aimed so far down to avoid glare the Light is going backwards If 6k is sunlight 12 K must be NUNlight
Keep up the good work minions
Old Mar 22, 2010 | 11:56 AM
  #47
ohlord's Avatar
Bigboss
my suggestion is after you do the install you might want to start driving backwards. After aiming the headlights down you may find you see the road better.
Old Mar 22, 2010 | 03:15 PM
  #48
vadimkag's Avatar
E320 4matic wagon
Originally Posted by SLOPESTAR
Vadimkag.
I know... sory. English my second lenguage.
Old Mar 22, 2010 | 06:31 PM
  #49
BigBoss's Avatar
Inline fuse?
I bet it won't be that bad.
Old Mar 23, 2010 | 12:48 AM
  #50
vadimkag's Avatar
E320 4matic wagon
It's nice and it worth it.
