How frequently and how long should I drive car which isn’t in use
I do not drive my old E class but I still want have it in working condition. Is there any recommendation of driving it periodically, let’s say once in 3 months for 50 miles. Will it keep a battery charged?
I have option to sale the car, but it looks like nobody wants to buy W210 anymore.
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
98 Brilliant Silver E320 Wagon
Once every two to three weeks is not enough for the battery. You can get what is called a 'float' charger at Harbor Freight, online, etc. It is designed to maintain a charged battery. That is it compensates for the small amount of drain experienced every day by CAN bus car.
Cars seem to perform best when driven regularly. Anything less is a struggle ending in disappointment and repairs.
If you don't need the car, sell it as suggested. It's going to be worth less as time passes. If you absolutely want to keep it, then do a long term storage as suggested but be prepared for some expense when you get ready to put it back on the road.
Good luck.
Good luck.
Good luck.
Good luck.
Beg your pardon but all my MB's sit sometimes for3 to 5 weeks when we are out of the country with no battery tender on them and we have never had an issue with any of them including a W210 when we had it. If it will not sit that long then there is an issue with the car or the battery itself.
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
3 to 5 weeks
between drives will shorten a batteries life greatly.
So your exception is poor advice. Keep it charged on a maintainer and you will have a long lasting battery and you won't put a Brobdingnagian strain on the alternator(which was never meant to charge a 5 week drained battery in the first place)
Leaving the country or not
1 Post
2014 E350 4matic, 2015 Acura TLX
The battery is not the only concern when storing a car. Depending on climate, the brake rotors can accumulate rust. If the car is not mover regularly, the tires will develop flat spots. Seals can dry out, etc. Although I generally don't drive mine in the winter, I try to get it out of the garage and drive it at least a half hour,once a week, assuming the roads are dry.
