Another BAS, ESP, ABS problem...
Old May 15, 2010 | 07:06 PM
brentkhack's Avatar
2010 ML350
01 E320 with the above problem. The error comes up as soon as the engine is started and stays on the whole time driving. The error starts even if I do or do not press the brake pedel when starting the car. I did the turn the steering wheel left then right then center and nothing happens. The car runs and drives fine. I have changed out the brake light swith (OEM). I did disconnect the battery for 15 mins and still the same problem. What would you say my next step should be (please don't say spend mega $$$ at the dealership)
Old May 16, 2010 | 10:45 AM
ohlord's Avatar
Check the brake
light sockets. Corrosion or disintegration at the wires bulb or socket can cause the symptoms especially when you have eliminated the possible brake switch.
Also make sure the bs in installed fully and properly.
Also car running in park and turn the wheel lock to lock and back several times,if that is not what you were doing (just in case)
Old May 17, 2010 | 12:49 PM
mi benz's Avatar
98 E300
just curious- why start another thread on this?
here is what fixed mine (from this thread):
Just wanted to post the solution to my ESP/ABS/BAS problem.
After trying the brake light switch to no avail, I had the codes scanned at a local indy shop and the lateral acceleration sensor had thrown a code. This module is part of the ESP system and is located under the carpet beneath the driver's seat. Believe it or not Mercedes wants > $2K for this module! I found it on a German used parts website for < 50 Euros I finally got it replaced today and the annoying beeps and lights are gone
It's MB part number 000 542 65 18.
good luck!<!-- google_ad_section_end --> <!-- / message -->
Last edited by mi benz; May 17, 2010 at 12:51 PM. Reason: added link to another thread
Old May 24, 2010 | 02:00 PM
f1shb0n3's Avatar
1999 Mercedes E320 Wagon 4Matic
Another possible solution - replace your battery.
This one of the common reasons according to another MB forum, and this is what fixed my BAS/ESP/ABS problem.
My battery was suposedly fine while it started first showing those errors. Even the Autozone tester said it was good. But two months later I almost couldn't start my car and decided to replace the battery. The BAS/ESP/ABS lights haven't lighted up at all after that.
Old May 26, 2010 | 05:42 AM
ibrahimsharaf's Avatar
Mercedes Benz E320 2003
Thumbs up Break Booster
Greetings,
I had exactly the same problem with the same message coming up, and after trying everything with everyone's help I took it to the dealer and found out that Break Booster was not functioning properly.
Old May 29, 2010 | 05:01 AM
Lancelot's Avatar
'01 W210 E320 CDI
It was the same with my car, replaced the brakelightswitch, checked sockets, had the car readout at the dealer, nothing conslusive. Changed out my apparantly fine battery for a Bosch Silver5 and never seen the error again. I've also NOT replaced a headlightbulb for more than a year now! The car was eating H7 bulbs before...
