Rev limiter at 4k rpm
I did get 2 fault codes, P0100 and p0110. I will have to look into these. No check engine light though.
DTC codes P0100 and P0110 are MAF circuit codes so make sure the connector is seated. Maybe disconnect and clean both male and female contacts with electrical contact cleaner and then reseat. Usually when MAF fails you get P0170 and P0173 which are fuel trim codes. Also you might buy some CRC MAF cleaner and clean the sensor. Post if you need DIY details.
It's important to keep the MAF sensor and the O2 sensors in good working order. When they stop working the exhaust gas becomes too rich and the catalytic convertor overheats and decomposes.
maybe you can check with a Star Diagnosis the RPM sensors in the electronic gearbox board (inside the valve body gear group,)
Fabio Daniel
i don't think that would be the shift indicator though....
hope you find what it is soon...
