1st gear in a Mercedes???
Old Jun 18, 2010 | 07:08 PM
austinholloman's Avatar
W203 C55 and SAAB 9-3 2.0T
Question 1st gear in a Mercedes???
Ive been around cars my whole life and I have never understood how Mercedes trannys work when it comes to starting out in second gear? I know on 80's and 90's models ive seen people mod them to start out in first. I had a 93 w124 400E and I thought it was in first gear when I would floor it from a dead stop but people would still tell me it wasnt. How does this work? And do the w210's start off is first or second? Im just confused.
Old Jun 18, 2010 | 09:13 PM
saintz's Avatar
GL450
There's a switch on the console by the shifter. In S (Summer, Sport) it starts in 1st. In W (Wet, Winter) it starts in 2nd. This is to reduce torque when traction is limited.
Old Jun 18, 2010 | 10:54 PM
How does it work on the older Mercs? Before there was an S/W option? Early 90's and 80's....
Old Jun 19, 2010 | 11:18 AM
TMAllison's Avatar
09' E320
80's & early 90's = Vacuum signal and throttle position.
Old Jun 20, 2010 | 09:54 PM
bmroxm5's Avatar
W210 E320
how do you fix a broken s/w switch?
my one used to alternate between starting in 1st and 2nd but now i flick the switch and it doesn't do anything. the only way to get it to start in 1st is floor it hard or manually move the shifter down the gate...
also I believe having it in S will give you quicker shift times, W will slow down shift times to ensure grip is maintained.
Old Jun 22, 2010 | 09:23 PM
E-420's Avatar
97 E-420
Winter/Summer???? I thought it was a "wife"/ "self" switch!!
Old Jun 23, 2010 | 01:15 AM
BordeauxW210's Avatar
W210 E430
Its technically W=Winter, and S=Standard. Winter starts off in 2nd, standard in 1st.
Old Jun 27, 2010 | 11:28 AM
Figuero's Avatar
2002 E430 4MATIC
Not sure what you mean by Quicker vs. Slower....but W will upshift at a lower rpm getting you into a higher gear sooner than S. Helps with traction in bad weather as you mention.
Old Jun 28, 2010 | 04:34 PM
ejsheltra's Avatar
2003 S210 3.8L Brabus wagon
Your tranny is an adaptive model meaning it will adapt to your driving style. If you manually hold gears longer then the shift points will raise. It will not shift any faster between gears however unless it is an AMG warmed tranny where the shift points are increased as well as the speed of the shift. Since the adaptive mode is a continually learning mode the transmission is always adapting to your driving style and as they say shift points may vary as your driving habits change over time. The W/S switch can only be replaced by replacing the shifting unit which can be had used at local parts houses like Potomac German Auto. They are a very easy DIY and there are many posts here on the forum.
