Cannot find a 2002 E320 driving light?
Old Aug 3, 2010 | 11:45 AM
dkraut's Avatar
What's the issue with these lights? I cannot find them anywhere?!?! It's the small round light next to the headlight. I just need a new bulb, not the entire light.
Old Aug 3, 2010 | 12:36 PM
saintz's Avatar
GL450
It's a H6W bulb with a BAX9S base. You can find them online (try eBay). You can probably get them cheapest from your dealer so you don't pay shipping. Auto parts stores will have H6W bulbs but with a different base. You'll need to remove a pin to make it work.
Old Aug 4, 2010 | 03:14 AM
01BlackE320's Avatar
01 E320
Instead of the H6 I used Sylvania 3893 (T4W) bulb which is readily available at Pep Boys. Bulb looks identical and works just fine. Slightly dimmer then the original bulb (4 watt vs 6 watt) but you'll barely notice it. If you replace both you definately wont notice it. The package is labeled License, Parking and Side Marker - European Lamps and its about $3 for two bulbs.
Old Aug 6, 2010 | 03:27 PM
kevinC's Avatar
I gave up looking for that bulb at all the usual sources and went to the dealer. The parts guy gave me one. As in gave me one.
Old Aug 6, 2010 | 08:12 PM
BigBoss's Avatar
2002 Mercedes Benz E320
For free?
I just bought a pair of LED ones from ebay for 6 dollars.
Old Aug 6, 2010 | 08:23 PM
kevinC's Avatar
Free.
Old Aug 7, 2011 | 10:12 AM
dkraut's Avatar
Great find... hopefully these lower wattage bulbs do not throw the light Malfunction error?
Old Aug 7, 2011 | 10:20 AM
Musikmann's Avatar
2001 E320 RWD - Brilliant Silver/Ash: 100,000+
There might be some confusion here. The small round light next to the large low beam headlight is the high beam. For that you need an H7 which is 55 watts. I know for a fact that Autohausaz sells those, but I don't know about the regular retailers like Advanced, etc. If you're in a hurry, just buy one from a dealer; they can't cost that much.
Old Aug 7, 2011 | 12:07 PM
kevinC's Avatar
I've picked up H7 bulbs at WalMart for about $10.
Old Aug 7, 2011 | 01:30 PM
ohlord's Avatar
There was no confusion
The OP was asking about the driving light also called the city light.
THe smaller of the 2 bulbs located in the smaller oval lamp.
it is H6W
The T4 is much dimmer,much much dimmer
Old Aug 7, 2011 | 04:56 PM
dkraut's Avatar
it is H6W
Correct. And let me save others some time... The T4 or "Sylvania 3893" will not fit into the H6 receptacle! the contact nubs on the H6 bulb are offset approximately 200 degrees whereas the contacts on the Sylvania 3893 are offset 180 degrees. There is no way to even insert the 3893 bulb into the stock receptacle!
Old Aug 7, 2011 | 06:58 PM
ohlord's Avatar
You grind off
the opposing nub.Pick the correct one.
Still lots dimmer.
Old Aug 11, 2011 | 04:13 PM
Musikmann's Avatar
There was no confusion. The OP was asking about the driving light also called the city light. THe smaller of the 2 bulbs located in the smaller oval lamp. it is H6W The T4 is much dimmer,much much dimmer
Sorry guys, I guess I was the one confused!
