timing chain stretch test
Thanks a lot....The help is much appreciated.
John<!-- google_ad_section_end --> <!-- / message -->
When properly maintained.Which is mobil1 0w40 fss change intervals approx 10k miles.
You are wasting money at 3-5k and over detergenting
the engine both not the best of practices.
of chain (e.g. 6" or something). then the shop manual will tell you to measure
and if it exceeds a certain figure, it's a no-go....and recommend replacement.
I will have to check tomorrow but i am pretty sure there is not even a chain strech measurement
The double row chains last a very long time, I wouldn't be worried about it at all. You would get warning signs before it ever streches by any decent amount.
That is the guide in the cover which is very, very close to the chain and the crank gear.
I have had hundreds of 112/113 front covers off and have seen marks on that guide before. If you look at the way the chain is that engine is run if it streched it would of lenghtend so the tensionor would of push it even farther away from that guide...
I would hate for you to replaced the chain and everything and still have a noise after you reinstall
If your timing chair was rubbing you would probably see more damage.
The horrible sound is gone. The chain was stretched. Now she purrs like a kitten
