normal halogen h/light convert xenon for w210
Any fault code will appear on the meter panel?
thk..
thk
thought not exactly plug and play, the differences should be fairly easy to
resolve.
the main lighting harness is essentially the same, but with the HID light, there
are additional connections used by the suspension to transmit telemetry adjust-
ments to the headlight. this is used by the headlight to autolevel the light
beam.
having said this, understand that i have not performed this swap first hand, but
feel confident that I could, with a few extra minutes of possible modifications.
if you can get the HID lights inexpensively, it's definitely worth considering.
if the ballast is OEM as well (should be Hella ballast) you may not incur the
light malfunction warning. a little challenging to say for sure, as you car isn't
a US model which i'm more familiar with.
i have a slightly different opinion in regards to HID kits and would not recommend
placing an HID bulb into an H7 designed headlight as they are not calibrated
for each other. the ensuing results is likely to be less precision in the cutoff
and a degree of uncontrollable glare
for your faded H7 headlight lens, you can try polishing it fairly inexpensively.
then add 65 watt halogen bulb as many have suggested on this forum (if
it's legal where you are)
resolve.
beam.
Thk u sir , for the information giving.
That is mean ,if OEM should be no problem. Am i right?I will consider to buy that 2nd hand xenon light to convert to mine car.Usually I like my car all part to be OEM.I don,t like aftermarket projector hid because of the quality.
Anywhere thk alot.
The aftermarket kits are always too bright IMO. The bulb has no shielding (the OEM D2R bulb does) and scatters the light completely around in the H7 reflector. When the lens is only slightly dirty it's blinding everyone. (Especially when these @ssholes with their "stadium lighting" are coming towards you when it's raining!)
In the Netherlands they have new legislation 'against' this.
From 01-01-2007 on, all cars fitted with HID's must have a reflector-lense or projector setup meant for HID. There must be a headlight washing system and automatic beam-height-adjustment.
Are u saying that the OEM xenon will not fit on my normal h/light?Will it to do alot of modification?
If you're asking if the OEM D2R HID bulb will fit your current headlight assembly, the answer is NO.
You'll need a complete OEM HID headlight assembly, ballasts, harness, etc. Also your current vacuüm-controlled hight-adjustment in the car wilt NOT work with OEM HID headlights.
OEM Xenon headlamps x 2
OEM Xenon ballast x 2
OEM Xenon bulbs x 2
OEM LWR height control unit
LWR Hella electric motors for headlmp adjust
Electric wiring harness (hundred of wires :S)
Lower control arm sensor with sticks x 2 (front/rear)
Miscs like: fuse, connectors, nuts, bolts, connectors, etc.
Maybe someone know about this kit called "Xenon ulterior conversion kit", i can check the part number to all of you guys i remember is B6... .. .. .. but i post it tomorrow
Fabio Daniel
OEM Xenon bulbs x 2
Fabio Daniel
Waiting your next reply on the part no.
B6 680 99 10
I would take some pics inside the box of all contents if anyone need it! Let me know
Fabio Daniel
I did this to mine years ago when I worked for MB. Using all factory parts the conversion still took several hours, and I had to get help from one of the master mechanics. The conversion was very difficult, not to mention the cost...
Your best bet is to purchase an aftermarket HID "Plug & Play" kit and have your factory lenses polished. Stay away from "non factory" looking temperature range bulbs. You're looking for Neutral White in the 5000 - 6000k range.
Let us know if you have any other questions.
Good luck
Good luck
Is not too expensive this kit, i paid 450$ +/-, here we go the pics inside the box:
(forgot to tell i get this kit for pre-face car's) i think is possible get the same kit by a newer models, anyway, the real hard installation on this kit is for the level adjutment, but if you want you can install the xenon headlamps without the level adjustment :S is not 100% necessary
Fabio Daniel
I Stay away from "non factory" looking temperature range bulbs. You're looking for Neutral White in the 5000 - 6000k range.
Neutral range for xenon MB OEM is 4300 kelvin not 5000-6000 Kelvin which is bluer in color.
Fabio Daniel[/QUOTE]
Fabio. Level adjustment is absolutely critical if you are running Xenon HID. You will blind the on coming driver which could lead to a fatality maybe your own. Please, give the right advice here and do not cut corners.
Fabio Daniel
Fabio Daniel
Fabio Daniel
Nemo: Yes, they are plug and play, but check your oem fuses by the headlights, XENON comes with 15 amp fuses
Fabio Daniel
Fabio Daniel
I will check the fuse.
