Squeaky Rear Camber Arms?....Speedybenz
I've noticed a new squeaking noise coming from them now. Is this common after a few years of use? Any way to lube them? Or are they worn out?
Thanks.
Thanks.
I dont think they have ever been lubricated.
You are right, the bearing/bushing may be worn. I also see some purple/reddish grease around the bearings. Does that mean I have to get new arms? I don't think his bushing/bearings are replaceable. Even so, it will take him years to produce.Has anyone tried Ghostriders camber arms? I am thinking to replace those.
Thanks.
Just saw this. As you know, my car has a full speedybenz suspension, with 6 adjustable links. I had a few [ or maybe it was all?] rod-ends replaced a few years ago after showing signs of wear.. Let me know if you still need yours fixed and I'll look-up where I bought them from.
All the best,
Steve
Here are the specs I was sent on the control arms by TKX Performance who measured them, then did the install and alignment:
left hand thread & right hand thread
5/8"-18 pitch
Bore on heim joints 0.625"
Threaded length 1.5". The rod ends I bought from QA1 have sku XMR10 & XML10.
