Sefoaming
Old Aug 7, 2011 | 09:07 AM
Merc314's Avatar
01 E430
Sefoaming
I am looking for procedures on useable vacuum lines to suck up the Seafoam. I think that I have found a line that runs from just forward of the throttle body and runs across the firewall and over to the driverside behind the windshield washer tank. Does anyone know if that is a acceptable vacuum line to use? If unplugged while running, will it throw a code? I have already done sea foam in the gas tank, and in the oil, so now I am wanting to clean the upper intake track by doing the vacuum route. Any help on this is much appreciated!! Thanks!
Old Aug 7, 2011 | 09:16 AM
Musikmann's Avatar
2001 E320 RWD - Brilliant Silver/Ash: 100,000+
If you unplug any vacuum line you will throw a code.
Old Aug 7, 2011 | 09:25 AM
Merc314's Avatar
01 E430
That must be MB specific. I could do it on my Audi's and Subaru, and Toyota.
Old Aug 7, 2011 | 09:31 AM
Musikmann's Avatar
I was shooting from the hip because I have never done it. But vacuum leaks can, and probably will, throw fuel trim codes. Better wait for ohlord's opinion!
Old Aug 8, 2011 | 03:39 PM
Merc314's Avatar
01 E430
CALLING OHLORD!!!!! Please chime in and give us a hand!!
Old Aug 8, 2011 | 05:47 PM
ohlord's Avatar
It won't
harm anything if it tosses a code.
When you hook it up again the code will clear after a few drive cycles.
Use the vac line to the brake master cylinder.
You won't be using the brakes anyway.
Put the seafoam in a large glass cup,with engine running and someone at the pedal have them raise the idle while you just tip the hose at an angle into the seafoam. You don't want to sip too much and stall the engine.
Just let it sip away
the whole cup.
These engines run so clean such measures are hardly ever needed
But if it makes you happy,Smoke away
Old Aug 8, 2011 | 08:09 PM
Merc314's Avatar
01 E430
Thanks Ohlord! I have a rubber line with a ball needle on it and that allows for slow suction and not to cause any issues. I have done it this way on my last 4 cars. So far so good!! Thank you for the help! Maybe I will create a DIY for a sticky!
Old Aug 10, 2011 | 10:38 AM
nsupra's Avatar
Please do make a sticky
Old Aug 22, 2011 | 10:20 PM
Merc314's Avatar
01 E430
I successfully disconnected a vacuum line without throwing a code!! I was able to seafoam without any issues!! Stay tuned for a DIY!!
Old Nov 15, 2012 | 01:03 AM
JohnnyRock's Avatar
1998 C43 AMG
the whole cup.
Bringing this one back from the dead....Can anyone provide a picture of the exact vacuum line from the brake MC to use?
Old Nov 15, 2012 | 12:39 PM
raymond g-'s Avatar
99 E320
from the 'other' board. most questions have been answered at one time or other so a simple search will work most of the time on peachparts, benzworld, and mbworld
