new alpine headunit will not turn on?
When I plug In the original Bose it works fine... any suggestions? I've tried e vevrythinng
Please help
Fabio Daniel
Fabio, are you just using one of the Euro antenna converters? Does FM work?
that was a problem with my headunit install... however, even hooked up backwards (the way most harness kits end up), the headunit will turn on... it will just lose it's memory when you turn the car off.....
grounds should all be common.... no need for a dedicated ground just for the radio. i don't know much about the bose system, but if the radio has 12v battery, 12v ignition, and a ground, it will turn on....
-erik
ps- i didn't have to splice into any wires other the the factory radio harness wires... maybe the bose wiring is different though?
-erik
i try to find the some idea about, but.. what do you think?Fabio Daniel
