Potential new owner: E320 with issues for free, should I?
I've been reading through these forums, and I would really appreciate your advice.
My parents have a e320 with 170k. The transmission has issues (stuck in first until hot, along with a grinding noise), but the car has been well maintained at the dealer for the last 10 years. They have offered to give to me to do whatever I'd like (sell it, dontate it, fix it, etc..)
Ideally I'd like to fix it, if it doesn't cost me a mint (north of $3k). I'm mechanically inclined and have always done my own automotive work including clutch jobs, head gasket repairs, transmission swaps, but on less sophisticated machinery like subarus, ford trucks and VWs.
Should I attempt to fix it, or is it going to be too much expense and bother?
In any case even if you do decide to get rid of it later on, having changed/fixed the tranny would increase the value of the car
Assuming it's a prefacelift model and in excellent condition except for the transmission it's probably worth fixing. The wholesale price of the car is probably around $3,000 - $4,000 so you could easily flip the car for that price - more if you are willing to try to go for retail which is harder to guage depending on location etc.
If it's a post facelift - it's a no brainer assuming all's well except the transmission - fix it and enjoy the ride or the profit if you prefer.
If the car has truly properly maintained at the dealer for the last 10 years your parents should have a long list of "recommended" repairs. (Even if they weren't really necessary at the time). That should give you a huge clue as to the true condition of the car. Have they had the dealer look at the transmission yet?
The car has been great for my parents, and my dad is **** about maintaining his cars, they always goes to the dealer, and he pays close attention to any 'issues' that come up. He's the kind of guy that gets his tires rebalanced once or twice a year because he detects increasing vibration in the steering wheel.
My plan is to read the codes with a OBD scanner and see if they match up with the 'classic' symptoms of a failed control unit. If it's a mechanical failure, I'm more hesitant, simply because of the number of unknowns (can I use a later MY2000+ tranny, which is supposedly stronger? Do I have to have the dealer reset the TCU/ECU if I do use a different tranny, etc...)
I'd really like to fix it and keep it as a daily driver, but I also don't need an expensive cantankerous prima dona in my stable at the moment. So I'll gather data from the car and then research, research, research....
All W210 V6s use the 722.6xx electronically controlled transmission. I'm sure there are small differences but I don't think a later one is 'stronger' except because it may have few miles and/or had better care.
Look around maybe you'll be able to find someone willing to come by and do a scan, which will save you a trip to the dealer, alternatively you can look around for a good Indi shop in your area, it might be worth it to tow the car there for a complete check-up(including the scan), which may give you a better idea on what to do next.
