Spark Plugs and Wires
I found the DIY on here and before I undertake this task I was wondering if there was anything I should know about (advice), how many wires I might need (12?) to buy and how many spark plugs (12?)?
Thanks in advance guys!
You do need the 17mm special boot removal tool to make the job easier and faster and not ruin perfectly good wires.
You could do the whole job for under $125 Cn. And takes even a novice only a few hours on a Sat morning. Don't use anti seize on the plugs.
Update: Just looked at the wires, they aren't even cracked... They look perfectly fine, that damn mechanic was trying to take me for a spin and probably wanted me to buy the wires just in case he broke the old ones while putting in the spark plugs. They also cracked my engine cover
You can use ngk 7090 plugs or bosch 7422. If your going to a parts store the NGKs are probably more readily available and actually theyre less expensive. I bought my Bosch plugs online. Mechanics always try to sell you wires
Plugs bosch,ngk,denso etc even have instructions on the box use no anti seize.
I found out that each cylinder take two spark plugs. Twelve spark plugs for a six cylinder engine. He replaced the spark plugs with a used set for free. The new one he ordered were lost in the inventory. I had to wait a few days for the repair. The shop only works on MB and he was a little behind.
The shop replaced two breather hoses, valve cover gasket right, twelve spark plugs and one air filter. Total parts $217.50 and labor $475.00.
http://www.pelicanparts.com/techarti..._and_Coils.htm
whunter@pelicanparts.com
Questions:
- Is the procedure for spark plug replacement for the E-430 similar to that of the E-320, or are there other issues to watch out for?
- Is there a part number for the 17 mm special boot tool? My MB parts guy didn't know of it right off the bat, but he said he'd call.
http://www.alamomotorsports.com/Magn..._mercedes.html
If you don't replace the wires, don't detach them from the coil packs, as one of the wires separated when my son-in-law removed it from the coil pack.
I discovered the issue with the coil pack bolt size. Given the inconsistencies in the forums, I bought 5-Point Tamperproof T27 and T30 sockets at PEP Boys. Although the packages state T27 and T30, the sockets are stamped TS27 and TS30. The TS30 was too big, and the TS27 managed to get one bolt off, but it was clearly the wrong socket. I looked around in my work bench drawer and found a six-point T30 socket, which fit like a glove. So that's what is needed - a six-point T30 socket.
Keeping in mind this is an E430 4-Matic, when the car was new the best highway mileage I got was about 23.5 mpg. Lately I've managed 21.5 mpg. We'll see if the new plugs restore or improve the performance. The old plugs didn't look too bad.
All told, it took about three hours. Next up, replacing the anti-freeze.
