Hickups?
Thanks in advance.
Car has been acting up all weekend.
I called the dealer and they just told me a standard answer, "Bring it in and we will check it out, oh by the way, we charge $95 per hour".
Just thought someone here may have had a similar experience.
I also know that your exhauts sensors get old and will start to cause this problem. You have 4-6 sensors under your car connected to your exhaust....They are black and blue..You can check out to make sure the are all connected good but you wont know if they are bad or good unless you have a tester.
best of luck
Thanks for replying, I did have the oil changed recently so I am sure that is not it.
But the O2 sensors may be just the problem.
I did have a check engine light on for the last month or so. I took it to a friend who hooked it to a computer and it was a faulty O2 sensor. I was told by a former MB mechanic that the sensors were not mechanically important to the car.
Is this a job that I can do on my own or do I h ave to take it to a dealer? Also, are there places that sell the sensors other than the dealers?
THanks
I do not know of any other place to buy them but you can try mercedesshop.com .... I will also ask a friend of mine if he has some in stock and he will hook you up....I will give you complete directions on how to do this. Save your money and do it yourself...Its eaiser then changing your air filter hehe.
I will get back to you tomorrow about my friend.....Also...Do you know which sensor went bad on the scan or can you do a scan again....Im 99.9% sure this is the prob....I'm new to working on benz but i raced about 6 GM cars hehe.
I really appreciate the info.
I have always thought that the O2 sensors were difficult to replace because I didn't know where they were. (still don't)
But if you say it is as easy as changing and air filter, I should have no problems replacing it myself.
I dont remember which o2 sensor it was. How many are there?
Are they interchangeable? If so, maybe I can start by replacing the first location with a new sensor and test drive it around and see if it solves the procblem. If not, I can change the 2nd one and so on.
By the way, your car looks great with that AMG interior.
Benz you rock!
Thanks for the comment on the car :p
As far as how many are on the car I do not have the answer to that right now...I did notice 2 when i was under there this past weekend but im sure there are 2 more in the front.....I'm going under the car today and I will let you know...
The bad part is....These are not interchangeable
The only way they could be interchangeable is to use the left side front and back ONLY on the left side...Wont work on the right. Same goes for the right side. I will ask my buddy today about that.Since you dont know where they are or what they look like...Just look under your car on the exhaust..You will see a black rope connect to the exhaust....thats it hehe. very easy.
Thanks Benz,
I will try as you have recommended and let you know how it turns out.
Last night i was going out and needed gas cause i was on E as E can get...My car started to hickup but I thought it was cause the gas was so low...Right when I pulled in the gas station it died on me next to the gas pump WHEW. I then filled her up and started to drive off with very bad hickups..I was thinking maybe the gas just needed to move around before it would be fine..So i drove around the parking lot a few times with nothing buy bad hickups...I knew something was wrong and it was not the gas...So i pulled over and checked my battery...I found that the cable was lose on the battery! I tightind it up and was on my way just fine...
Might wanna check your battery as well..I forgot about this hehe.
Hope everything works out fine for you
I was out of town this weekend and have not had a chance to do anything to the car. Will work on it this weekend and will let you know. I will also check my battery connections.
Damn, I am so busy.
Well after a few weeks of trial and error, my hickup problem has been fixed. It turned out to be not related to the O2 Sensor. I also did try out the battery connections that you mentioned. They were fine.
I had to take the car to a Mercedes mechanic in my area.
He had the same computer that the dealer uses and it told of the problem right away.
It was a faulty coil. We replaced it and now it runs fine.
They did also look at the engine harness and it was fine.
The car is running well now. I guess I dont have an excuse to buy a new E55 now.
Benz,
