How to remove headlights? Just a quickie.
Old Jun 12, 2012 | 12:52 PM
skj0lsvik's Avatar
E220 W210
Hey all,
I've looked at several videos about removing headlights, but most of them cover the pre-facelift model. Do I remove my headlights the same way? Mine is a facelift.
And one more, the most important one...
How should I split the glass from the light? The glass is grey and dirty inside you see :S
Old Jun 12, 2012 | 01:43 PM
raymond g-'s Avatar
99 E320
i'll have to go home and check my notes on headlight removal. bumper loosening
or removal is required so it isn't as quick as the 96-99.
to remove the outer lens, you will need to remove clamps and then use a
heat bun to soften the sealant (or place in 100º ish oven for a few mins).
lens is then pried out. sealant reuseable but will need to be softened again
oh...i'm re-reading your post and have a question: what year is your car?
i'm not familiar with 220s so guessing your model is not an USA release
Old Jun 12, 2012 | 06:32 PM
suicidal4life's Avatar
2001 E430
As Raymond said you have to remove the bumper on the facelifts. I used Peter's DIY when I did mine. Once the bumper is off the headlight removal is pretty straight forward.
https://mbworld.org/forums/w210-amg/...mper-w210.html
Old Jun 13, 2012 | 08:56 AM
skj0lsvik's Avatar
E220 W210
A lill'bit more work but that's okey. Big thanks goes to both of you
Old Jun 19, 2012 | 10:59 AM
renault12ts's Avatar
W215 CL500 2005
There is a very useful thread about bumper removal:
