Windows open by themselves and lights flash after Hurricane Sandy
Also the SRS light stays on now. help!! I want to keep this car
pump, relay, black box modules, electrical contact, etc you can see
surrounding the battery and clean, wipe down, apply contact cleaner, check
fuse continuity, blow dry, replace foam (or seriously blot the heck dry), place
in uncooked rice, etc. add tons of ventilation for days, too. that's the easy
part. then after you've done all this, carefully check for function and report
back.
also, quit driving it. each time you power it up, you risk shorting more electrical
and electronic components.
back.
this was an older 210 DIY fix i had in my notes but sadly the person who posted
and hosted the photos are no longer. wonder if you can email or PM them
directly for more info?
Fabio Daniel
Fabio Daniel
Fabio Daniel
Fabio Daniel
Can you explain how those lower clips work? anyway its a lot easier job to replace the PSE knowing you dont have to disconnect all of those yellow hoses and can just swap in the hose assembly.
its working ok now except thetrunk release function seems to freeze up in a few days requiring a power reset. at least the windows dont open by themselves anymore!
Let me know any news and try to do the job as soon as possible!
Fabio Daniel
Fabio Daniel
, well i live in Venezuela (here, we no have hurricanes, storms, tsunamis, we no have common natural dissasters here) but we have here the most M***F***** president EVER!!! This is a real dissaster in my country
trust me, this As..H... is the worst president in the americas..
we are trusting in God to help us..Well, i recommend you to try to oppen the plastic harness and remove the rusted pins cause it will corrode the female pins in the harness giving you some troubles when you replace the pse unit (In the future), you can remove one little plastic portion in the rear side of the connector (you would slide it with your fingers), then insert a little flat head screwdriver to remove the connector cover itself. This way you got access to the wires/pins one by one (not scare, the pins/wires not pop off to the plastic part) this way you got the possibility to remove the rusted parts by the female pins.
Hope it helps mate, and if you need other help i'm glad to help you friend
Fabio Daniel
