Climate control
Old 02-20-2013, 02:08 PM
Plutoe's Avatar
Received 1,021 Likes on 949 Posts
1999 E300TD
Originally Posted by Gcarpenter
I tried, but cannot get the second test to work. I followed the direction exactly, no matter how long I hold down the EC and Rest buttons, nothing happens on the screen.
10000 other folks have successfully run the test-----read the instructions again and do the test again. Try to have one person read the instructions to you while you push the buttons.
This would be a good test or bonding exercise for you and your girlfriend!!
Old 02-20-2013, 05:23 PM
skj0lsvik's Avatar
E220 W210
Had the same problem, try having the hi and low temps opposite of what the directions tell you to. It worked with me that way
Old 02-20-2013, 07:02 PM
Plutoe's Avatar
1999 E300TD
Originally Posted by Plutoe
There are two parts---reading actual values and reading faults. You need both to fully understand what is going on.
READING ACTUAL VALUES:--------AC must be running to retrieve actual values!!
Ignition---position 1
Press the auto button and set temps to 72F or equivalent C
Press the Rest button for 5 seconds or more
The left side of the display will show number"1" and a value for In car Temp
Then press Auto again for the next number and corresponding value
Keep pressing and writing down the numbers and values till "12"
To end the process press Rest----you are half way done!!
READING FAULT DIAGNOSIS:
Ignition in position 1
Set Left Temp to HI
Set Right Temp to LO
Within twenty seconds simultaneously press the rest and EC for more than 5 seconds
The screen will flash "dl R"
Now press the right Auto button one at a time until all faults are displayed and recorded
All faults must be read out before they can be cleared.
To clear all faults press both auto buttons for more that 2 seconds and a "d" will be displayed on the left and "FF" is displayed on the right
Now go back and reset you cabin temps---ignition off------end of test
Good Luck and after clearing the faults there will be no red light on the EC button, but will return if you do not fix what is faulty.
In your case that will be late summer, Oh well
Revised 022013
Old 02-20-2013, 07:05 PM
Plutoe's Avatar
1999 E300TD
You are correct-----thank you--- and the instructions corrected to what you encountered-----now 10000 more folks can read their AC faults
Old 02-20-2013, 07:52 PM
Gcarpenter's Avatar
03 C32 amg, 2002 ML320
Thanks, I got the first test to run without problem. Hope this works for the second test.
Old 03-20-2013, 01:39 AM
khangee's Avatar
1990 300SE, 97 E420, 2001 E430
MY 2001 E430. I get one E61 416 error code. Does that mean Coolant circulation pump gone bad. I do hear whising sound coming from center vent.
Old 03-20-2013, 08:04 AM
  #32
Plutoe's Avatar
1999 E300TD
1416 fault refers to the heater inline circulation pump. If you look at your manual and the AC controls you will see a button to push when you want to circulate warm heater water when the engine is off.
With a faulty pump you will need to keep the engine running to circulate the hot heater water-----
Old 05-11-2013, 02:17 PM
  #33
RC46's Avatar
97 Dodge Ram 4x4
Help please
AC not getting cold and EC light was on..
And In Vegas no AC...NO BUENO!
Here are my codes.
29
25
30
30
28
38
02
26
05
2.6
2.8
4.2
EB1 234
EB1 241
E FF
any help would be appreciated.. And if you are in Vegas soon I will buy you a beer, or 5..
Old 05-11-2013, 04:15 PM
  #34
Plutoe's Avatar
1999 E300TD
I'll be brief----you have a leak and low on refrig(1241)---thats why the compressor stopped(EC light)-------find the leak, fix the leak,clear the faults---enjoy your stay in Veges--if you are not good at leaks---find an AC shop that does!!
Quick Reply: Climate control
