2009 C300 AMG WHEELS FIT 1999 E430
Old Mar 5, 2013 | 05:53 PM
KZ442's Avatar
E430,Triumph Spitfire, Oldsmobile 442
Hi,
I have a chance to get a set of 18 inch AMG wheels off a 2009 C300 from a friend, will they fit my 99 e430?
Thanks,
Old Mar 5, 2013 | 07:11 PM
matt72's Avatar
c124 124.051
i think you will need 20mm spacers,try and post the rim size and offset to be sure.
Old Mar 5, 2013 | 07:33 PM
KZ442's Avatar
My offset on the e430 is 35mm and the C300 wheels are 45mm, the bolt pattern is the same.
Old Mar 5, 2013 | 07:36 PM
matt72's Avatar
c124 124.051
if the rim width is 8.5 then you will need a 10mm spacer
Old Mar 5, 2013 | 08:16 PM
KZ442's Avatar
Thanks,
So the larger mm means the wheel is tucked in more inside the fender and the lower mm it is more towards the outter?
Old Mar 5, 2013 | 08:26 PM
matt72's Avatar
c124 124.051
thats correct
Old Mar 5, 2013 | 08:42 PM
raymond g-'s Avatar
99 E320
i do not know for sure, but there is a high probability that the lug diameter/
ball seat of the 2009 wheel will be larger than the 12mm/12R of your w210.
though your smaller bolts will fit, they will lack the same/sufficient bearing
surface on the ball seat. many newer rims from MB are of the 14mm/14R
design.
also, depending the the width of the wheel between ball seat bottom and the
mounting surface of the hub, your existing lug may be the wrong depth. if
too long, the bolt will intrude in the area of the parking break. any attempt
to drive in that condition may severely damage your rear brakes.
Old Mar 6, 2013 | 12:03 PM
KZ442's Avatar
Thanks All,
I will check the wheels out and make sure everything is cool before I just drive off. I pick this e430 up with only 40k on it and she is pretty clean I just don't care to much for the factory rims.
Thanks,
Old Mar 6, 2013 | 12:07 PM
matt72's Avatar
c124 124.051
post a pic when you have them on,it should look very nice
