Whistling sound from interior A/C
Old Mar 16, 2013 | 12:14 AM
Paronoff's Avatar
2001 E320
Starting to warm up in Southern California so turned the A/C on. Air cold. Fan speeds work but slight whistling sound from right side of dash. Sounds like wind noise but still happens when car is stopped. Doesn't seem to get louder by increasing fan speed. Anyone know what could be causing this?
Old Mar 16, 2013 | 08:17 AM
mtrevelino's Avatar
2006 E320 CDI
I know that this is a dumb suggestion, but are ALL the air vents open? In my e320, sometimes my wife will shut off her window vent, and at times the system will whistle.
Mike T.
Old Mar 17, 2013 | 02:54 PM
Paronoff's Avatar
2001 E320
I will check on the vents and run the diagnostic and report back.
Old Mar 20, 2013 | 06:26 PM
Paronoff's Avatar
2001 E320
Tested unit. No faults. Passenger side vent open. Starting to sound like fan noise. I noticed at higher fan rpm noise goes away.
Old Mar 20, 2013 | 07:09 PM
mtrevelino's Avatar
2006 E320 CDI
Don't forget to look at the rear vents (if you have any).
Mike T.
Old Mar 20, 2013 | 10:14 PM
Paronoff's Avatar
2001 E320
I will remove cabin air filters and try some canned air.
Old Mar 25, 2013 | 12:57 PM
track_warrior's Avatar
Like The Stig
You are low on R-134A refrigerant. Go buy a can at autozone and check to see if that solves the problem. My ac started whistling as well, i filled her up and the whistling stopped, it was more of a hissing sound though.
Old Mar 26, 2013 | 12:02 AM
C280 Sport's Avatar
MB’s of all kinds.
Yupp. Low on freon will make it sound like a whistling sound or cracking sound too as many described. Also, is the EC light on? If so you are very very low.
Old Mar 27, 2013 | 12:43 AM
Paronoff's Avatar
2001 E320
No lights no faults. Haven't had a chance to take cabin filters out and blow air through vents. If it doesn't rain this weekend, I will do it and report back.
Old Apr 3, 2013 | 08:56 PM
Paronoff's Avatar
2001 E320
Still can't find the cause of the intermittent whistle. Ran tests again. Found one fault Eb1. 234. Which I understand is the sun sensor. Turned on air with windshield covered which probably triggered the fault. Cleared it and will re check. Here is latest A/C values.
1 80
2 94
3 40
4 40
5 32
6 184
7 15
8 120
Old Apr 3, 2013 | 09:45 PM
MagCL's Avatar
CL55, S550, 450SL
Make sure the cabin air filters are installed properly and are clean. I had a whistling as well on my old W220 so I replaced the filters in the glove box and the whistling went away. It's worth a shot!!
Old Apr 3, 2013 | 10:23 PM
Paronoff's Avatar
2001 E320
First thing I tried. It helped the airflow because the old ones were dirty. I think a tiny twig or leaf is keeping one of the dampers from positioning properly. I hope it is not the passenger side fan. If so, I will fix when it gets worse. Until then the A/C is blowing cold. It is a minor irritation fixed by playing the radio louder. Thank you all for trying to help.
Old Apr 4, 2013 | 09:43 PM
MagCL's Avatar
CL55, S550, 450SL
Your car may have a carbon filter under the dash. Check that as well (if you haven't already).
Old Apr 6, 2013 | 04:02 PM
Paronoff's Avatar
2001 E320
I will check those but I think I will have a pro look at the A/C system.
