1996yr E230 Instrument Panel
Old 05-03-2013, 04:08 AM
koh_424's Avatar
W210 E230
Dear all,
Would like to ask, is there any warning light i have miss out in the instrument panel?
Cheers.
<a href="http://s243.photobucket.com/user/koh_424/media/IMG_1005-1.jpg.html" target="_blank"><img src="http://i243.photobucket.com/albums/ff29/koh_424/IMG_1005-1.jpg" border="0" alt="W210 E230 Instrument Panel photo IMG_1005-1.jpg"/></a>
Old 05-03-2013, 07:57 AM
Plutoe's Avatar
Received 1,044 Likes on 967 Posts
1999 E300TD
Why are you asking??
Old 05-03-2013, 08:04 AM
koh_424's Avatar
W210 E230
I mean is there any other warning bulb burnt?
Old 05-03-2013, 09:24 AM
Plutoe's Avatar
1999 E300TD
The quickest way to get an answer to your question is----- check your owners manual---there are loads of IC with different features-----
Old 05-03-2013, 10:11 AM
koh_424's Avatar
W210 E230
Have checked user manual. But due to the user manual stated for e280/e300/e320 & etc. I unable to figure out which IC does tis car have.
Cheers.
Old 05-03-2013, 10:30 AM
Plutoe's Avatar
1999 E300TD
My EPC is down awaiting update therefore can't search by VIN however will check WIS and use a generic E230. Be patient!!
Old 05-03-2013, 10:41 AM
koh_424's Avatar
W210 E230
U mean this coding??
Mercedes-Benz W210 E230 1996
Datacard
Identification number: WDB2100376A076740 4
Chassis
Sales designation: E 230
Order number: 0 6 855 10155
Delivery date: 29 01 1996
Paint code 1: 744 No code designation available
Equipment: 108A MB-TEX GREY
Engine no.: 111970 62
Transmission: 722440 03 945468
SA code
100A MB-TEX
108A MB-TEX GREY
249 AUTOMATICALLY DIPPING INSIDE REAR VIEW MIRROR
292 SIDEBAG
420 FSG TRANSMISSION (5+E MANUAL TRANSMISSION)
543 SUN VISOR WITH MAKE-UP MIRROR L. AND R., BE-
570 FOLDING ARMREST, FRONT
580 AIR CONDITIONER
611 EXIT LIGHTS FOR DRIVER DOORS
613 LAMP UNIT - ASSYMETRICAL, LH TRAFFIC
656 LIGHT ALLOY WHEELS, 10-HOLE
718 CKD-VEHICLES - RANGE OF DELIVERY - MALAYSIA
955 EQUIPMENT PACKAGE ELEGANCE
Old 05-03-2013, 12:37 PM
Plutoe's Avatar
1999 E300TD
I tried without the ability to use your VIN.
All I can say is that you are missing ASR, seat belt, high beam and fuel reserve(missing one lower and two R and L indicators, a total of 5 bulbs)
Test those functions to see if the bulbs are not burnt out, however a MUCH more simpler approach is to pull the cluster.
Old 05-03-2013, 09:04 PM
koh_424's Avatar
W210 E230
Thx for the reply bro.
The high beam n LR signal still available.
Seat belt, ASR & fuel reserve I might nid check.
May I know wat is ASR stand for?
For my version, the steering can't b adjust so is hard to approach the instrument cluster.
Cheers
Old 05-04-2013, 10:30 AM
Plutoe's Avatar
1999 E300TD
Yep-----you gotta take off the steering wheel to get to the cluster---oh well!!
The ASR(acceleration slip regulation) is apart of the ETS(electronic traction system)---it's all described in much detail in you owners manual---spend some time reading and searching
Old 05-04-2013, 10:47 AM
koh_424's Avatar
W210 E230
May I know which the fuel reserve, ASR, & seat belt sign located?
Old 05-04-2013, 01:00 PM
Plutoe's Avatar
1999 E300TD
Without my ability to check by your VIN-------I have no idea where they are located or if your car even has those features----look at my post 8
Old 05-04-2013, 08:25 PM
koh_424's Avatar
W210 E230
Tis number unable to check?
WDB2100376A076740
Old 05-05-2013, 06:39 AM
Plutoe's Avatar
1999 E300TD
WDB2100376A076740
Like I said in previous posts my EPC is down and unable to check by VIN----If you want to wait, My EPC will be updated and in operation 070512 1700 and then I can check
Old 05-05-2013, 06:41 AM
koh_424's Avatar
W210 E230
Yeah...plz help me check the VIN
Will wait for u!
Old 05-06-2013, 02:29 PM
Plutoe's Avatar
1999 E300TD
I got my system updated a day earlier and now up and running!!
Checked by your VIN----did the car come from Japan(FYI the car does not have the ASR system)???
In any event there are two indicator bulbs on the lower left side and going from R to L they are brake fluid level and seat belt warning.
On the upper most right side there is one indicator lamp above the battery, however I looked in WIS and EPC and I just can't find the description for the lamp--very sorry---- I just can't spend more time on this project------search a manual or call the dealer!!
Old 05-06-2013, 08:18 PM
koh_424's Avatar
W210 E230
Thanks for the VIN checking bro.
I not too sure where is the car origin from as the previous owner never mention much to me. But i will find out later.
Bout the instrument panel, both side bottom L & R i have tested it out. But it never shown any sign of the warning light come on. As well the upper of right side tested but not sign of any light come on too.
Old 05-30-2013, 12:47 PM
markojan's Avatar
w210 1996 E200 Elegance
i have e200 1996. and the same light come on when i turn ignition. you can turn the lights,push the high beam leaver to check the indicator on the right in line with others (should glow blue) , press hazard lights to chech L/R turn lights.
there are 2 more bulbs on the bottom right, the wheel symbol (probably steering wheel pressure or oil level) and seatbelt symbol but they never turn on on my mercedes either so you're GOOD TRUST ME !
maybe on 1997. versions is something diferent , but on the first ones since 124 that's it
Old 05-30-2013, 08:18 PM
koh_424's Avatar
W210 E230
U mean the bottom right still have 2 more warning light?
But i plugged in the bulb n test. Can't c any light come on. Do they using the same bulb?
Old 05-30-2013, 08:31 PM
Tacjam's Avatar
2000 W210 E55// 2007 Toyota Tacoma X-Runner
Is the cluster removal different than 00-02? I'm trying to figure out why you'd have to remove the steering wheel?
Old 05-30-2013, 09:27 PM
koh_424's Avatar
W210 E230
Due to the steering column is not adjustable. I will need to dismantle the steering wheel so tat i can reach the instrument panel easier.
Old 05-31-2013, 12:36 AM
markojan's Avatar
Bulbs are working but for some reason those 2 never light on on any occasion on mine too
So everything is OK and as it should bebon mine and yours because that is normal for 1996 models....
You dont need to dismantle the steering wheel. Just pull out intsrumet cluster, than disconnect the left and right sockets and slide the cluster to the right....
Old 05-31-2013, 01:42 AM
koh_424's Avatar
W210 E230
Urs also the bottom 2 lights never come on?
Old 05-31-2013, 03:28 AM
markojan's Avatar
yes. there are 2 bulbs fitet for 2 warnings under ABS (steering wheel and seatbelt) inside but NEVER come on .... the ones on the right are without bulbs and have some tape over them.
Old 05-31-2013, 03:31 AM
koh_424's Avatar
W210 E230
Does the seat belt warning light come on with our standard spec (1996)?
Quick Reply: 1996yr E230 Instrument Panel
