2000 Mercedes Benz E320 Brake lights stopped working
Old Aug 15, 2013 | 03:14 AM
PSingh's Avatar
Hello Everybody,
One of the brake lights on my car was not working. I took the light holder out and tried to put it in again. There was a little spark, after which all three brake lights stopped working. I checked all the fuses and they were fine. All the other lights like tail lights, headlights etc. are working fine. Any ideas what could have gone wrong? Thanks in advance.
PS
Old Aug 15, 2013 | 07:49 PM
nelbur's Avatar
1997 E300D
My guess is that you blew a fuse. Did you find out which fuse works the brake light circuit. It might be in the box on the dash that is exposed when you open the drivers door, at least that is where it is in the US version. The bulb holder contacts will often make poor contact with the metal on the tail light assembly, sometimes burning a spot on the assembly, and sometimes melting the plastic under the metal strips.
Old Aug 16, 2013 | 01:38 AM
PSingh's Avatar
Dear Nelbur,
Thanks for your response. You are right it was fuses. Yesterday I checked wrong fuses because the owner's manual did not give much information. This morning I called Mercedes dealership, got the right fuse numbers, changed the fuses, and the lights worked just fine.
-PSingh
Old Oct 17, 2024 | 01:07 PM
yousaf72's Avatar
Originally Posted by PSingh
Dear Nelbur,
-PSingh
PSing
I have exactly the same car and same issue. Can youm please send me the fuse numbers?
Old Oct 17, 2024 | 01:30 PM
yousaf72's Avatar
Fuse numbers
Hi
I have the exact same car (2000 Mercedez E320) with the same problem. Could you please share the fuse numbers?
Old Oct 20, 2024 | 09:24 PM
nelbur's Avatar
1997 E300D
Of course there are fuses for the brake light circuit. Possibly more than one. I don't have your car but look on the drivers end of the dash on US cars, if you can't find them in the under hood fuse box. The purpose of each fuse should be listed on the back of the box door, if not near each fuse.
Old Oct 21, 2024 | 10:41 PM
raymond g-'s Avatar
99 E320
some fuse maps posted here under "Fuise"
https://www.benzworld.org/threads/0-...order.1720154/
