New member here with an 02 E430 sport brabus question
02 E430 Sport
02 E430 Sport
i wasnt asking about diameter wise or rubbing wise, i was asking about the hub mating surface. can i use my stock lug bolts or do i need different ones or spacers?
im kind of experienced on stance and fitment on Lexus vehicles so i can deal with making wheels fit without rubbing.
heres the specs though 20x9.5 +35 all around, 225-35-20 tires with a mild stretch.
c124 124.051
i am sure you are aware that there are two types of seat on bolts, and i think brabus are different to mb,take a wheel off and measure how much the bolt pokes through the wheel,then compare to the brabus wheel,the back wheels are the ones to watch,too long and you will chew your hand brake shoes up. Fit the wheel and spin it,listen for noise,before driving.check centre bore,you may need hub rings. i think you will need one inch spacers on front,i think they will stick out beyond the wing though. can you make fronts an inch narrower ? et 35 on 8.5 is good for front
02 E430 Sport
what do i need 1" spacers for in the front? the front calipers dont look big at all, i do have lorinser 7mm spacers that are hubcentric to the wheels and the hub that i was planning to use on the front.
about the wheels they are 9.5" wide i cant make them narrower. but the tires are a little stretch. im going to test fit today.
c124 124.051
its not the caliper thats the problem,its the strut i think,when you go round corners and the wheel is turned inward,i think you will have a problem then,also tire size needs to be checked. if the overrall diameter is different to factory spec,you may have anything from no abs,esp to cruise control not working,check on a tire calcultor
02 E430 Sport
you are correct everything is functioning fine. the wheels are on the car i will post pics tomorrow.
02 E430 Sport
Nice rims! I did a stud kit with Honda ball seat lugs for my monoblock VIs. #1 pads and eibach springs would give you a nice 2 inch drop.
02 E430 Sport
i like the eibach springs but im not familiar with #1 pads, what is that?
with the 2" drop can i get my camber close to spec or will it be way off?
i was running -3.5 all around before but i rather not have too much negative camber on this car.
There are rubber pads that the top of the coil springs sit in. Mercedes sells them in different thicknesses to adjust the height of the car based on the weight of the different options it was ordered with. The pads have from 1-5 bumps on them. 1 is the shortest and 5 is the tallest. Here is a link with a pic and some part numbers.
http://www.benzworld.org/forums/w210...d-03-14-a.html
02 E430 Sport
Our cars can be within spec at around -2.5 degrees camber I believe. With eibach springs I was still within spec...until I cut a coil lol.
02 E430 Sport
A pic with just the eibachs? or with the cut eibachs?
Ill have to dig them up because this was back in like 05 lol
Unfortunately the pics I had were on imagestation, lol. had to look back to my posts from 2005. If you look at my build thread you can see with one coil cut in front in the first pic. that's on 20s. The rears with no coils cut was in spec, but the front was pretty cambered out...went through tires like mad.
02 E430 Sport
c124 124.051
i have no idea of prices in us but here in europe they would be worth about 800€. imho amg monoblocks,like the e55 are the best suited wheel for w210,especially with the sport kit,but if you do go ahead with these just check they are original as there are lots of fake versions on this design,you may need some custom bolts if they have 14mm bolt holes also. good luck
