W210 EPC-light stays on but disappear after restarting the car
I'm thinking a bad sensor or something, but i'm kinda fresh to both the car and mercedes in general. Anyone had a similar issue?
Would be very grateful for any help at all!
!http://www.mbclub.co.uk/forums/engin...c-warning.html
ZAYED,,
ZAYED,,
That's the thing, if i don't restart my car and leave the light on, nothing changes. It still handles and sounds the same, no cut-off issues or nothing.. Think i need to get my hands on an OBD reader to figure this one out..
Hoping someone here with any experience could help me with understanding the codes, as i'm new to the whole OBD-scene..
Thanks in advance
The light persists, but since winter temperatures are here, the first time i start the car, the light disappears till next time i restart the car, then it's the same procedure.
Any ideas?
If the alternator is working well, your multi-meter should read between (13.6>>>14.4),
If it is reading higher than 14.8>>15.5 volts (greater than 15 volts) it is possible that the alternator regulator going bad,
If meter reading lower than 12.8<<<13.2 volts, it may have bad battery or engine idle is too low for the alternator to put out sufficient voltage,,
also check the condition of your battery & v-belt isn't get loose...
ZAYED,,
ZAYED,,
