Coming up on 50Kmi...what needs to be replaced?
Old 01-26-2004, 11:39 PM
jbol's Avatar
I should hit 50k in a few months and was wondering what items need to be replaced or at least looked at before the warranty expires. I should also think about an extended warranty...any suggestions? I'm in CA so I think that limits the choices as when I last checked no one offered extended warranties in CA.
Oh yeah, I have a 2001 E Wagon
Old 01-27-2004, 03:46 AM
The Godfather's Avatar
4 wheeled car.
harmonic balancer
Old 01-27-2004, 02:57 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
Re: Coming up on 50Kmi...what needs to be replaced?
Here is a couple of contacts...go DIRECT...and Avoid the Middle man..cough cough..STEALERSHIP...
Stan allen 330 633 0436
MBA 800 352 7676
American Bankers 800 669 0606
Do Your Home work and Compare rates and coverages
Lots of Other Insurance companies to pick from!!
Email me if you Need a list of Items to Check
Old 01-27-2004, 10:55 PM
Big J's Avatar
E430, Ferrari 360 Modena, BMW m3
Hi to everyone!
I'm a new member, and would like to know what is harmonic
balancer is , and for.. thanks
Old 01-28-2004, 04:54 AM
Randy B's Avatar
**SOLD***2003 E500
Transmission Fluid and Filter!
Old 01-28-2004, 04:58 AM
4 wheeled car.
Originally posted by Big J
Hi to everyone!
http://www.mercedesshop.com/shopforu...threadid=63512
Old 01-28-2004, 11:18 PM
T100T's Avatar
2010 E550
There is a known problem with something in the seat frame or seat mounting that wears out and results in the seats clicking when you move away from a stop having slowed down hard. There is no repair and the replacement parts are expensive. You'll find references to this if you search.
Secondly the power window mechanism, not the motor but the mechanism connected to the glass is pretty weak. In my case the rear windows were never used and when I did try them after over 12 months of inactivity one of them broke. Again they're a known weak link.
Finally, while I don't think it is a general weakness but has failed on my car and is expensive to fix I'd have someone run a sniffer on the AC system. I don't think the test is very expensive and the repairs (evaporator in my case) is steep (over $4k).
Good luck,
Peter
Old 01-29-2004, 02:21 AM
carlsson9's Avatar
Mercedes W210 E280
funny you should mention about the window mechanism. Had my car tinted 2 weeks ago, and my rear window (driver side) broke because of wear and tear. cost's less then US70 to fix.
My air con did fry when it hit 50,000 km. Had to change the whole air con unit at US2500 a pop..
i guess just check your bushes and suspensions, plus headlight mounts melts pretty easily.
Quick Reply: Coming up on 50Kmi...what needs to be replaced?
