Just did tune-up now rough running
Old Sep 21, 2015 | 01:00 PM
markwemple's Avatar
1998 E320 Wagon
1998 w210 e320. Just did: plugs, cleaned MAF, air filter, oil change, fuel filter, radiator, hoses, belt (other stuff but don't believe related to running.
Now, when I start it, it will only runabout 2 seconds. I can keep it running with the throttle but its rough around the idle point. It almost acts like a vacuum leak would in the old CIS days.
Don't know. Ideas? and I don't have a OBD-2 scanner.
TIA!
Old Sep 21, 2015 | 10:53 PM
Tall Giraffe's Avatar
2001 E55 OMG
Depends how and what you used to clean the MAF. Assuming you chose the right sparks, everything else should be ok. I usually reset the CPU when I clean the MAF and let it sit overnight without battery -usually does the trick. Turn steering wheel lock to lock for the ABS warning if you do.
Old Sep 22, 2015 | 09:38 AM
markwemple's Avatar
1998 E320 Wagon
Used CRC MAF cleaner. Not for any reason but just as a SOP for me since I had it apart. Well, a buddy suggested that I disconnect it and sure enough, it ran. Reconnected and it stopped running. So there's one problem. Getting a new one.
Old Sep 22, 2015 | 05:29 PM
markwemple's Avatar
1998 E320 Wagon
As a test, I changed my MAF for one off a 2000 e320 that runs fine. I still have the same problem.
Old Sep 22, 2015 | 09:54 PM
2001 E55 OMG
The other fixes should not cause such hiccups. Its either the MAF or the plugs in some way imo. I still say either a good clean of the MAF again using your MAF cleaner and disconnect the battery overnight or wait for a the new if you ordered and reset it via star or disconnect battery. I believe you can order the sensor on its own versus ordering the entire assembly to save some money- just have to have the right security bits.
I think with the other working maf, the ecu does not recognize the readings from the metering. Same for the newly cleaned one. I had this problem when I first bought my car and ended up replacing it with a reset and new life appeared. I never tested the old one but I do have it just in case of emergency.
Good Luck!
Old Sep 23, 2015 | 10:38 AM
markwemple's Avatar
1998 E320 Wagon
How long does the battery need to be disconnected to re-set??
Old Sep 23, 2015 | 07:34 PM
2001 E55 OMG
Id say minimum 1 hour but an overnighter will not hurt.
Old Sep 24, 2015 | 09:20 AM
markwemple's Avatar
1998 E320 Wagon
Turned out to be a large vacuum line off the back of the intake manifold. Plastic piece that comes out of the manifold and into the line broke off. It is RTVed into place now but I need to buy/find a new one.
Old Sep 24, 2015 | 09:50 AM
2001 E55 OMG
Glad you found the issue. Those plastic bits and connectors are brittle. I changed mine when I resealed my breather covers/valve gasket in my case. Bought mine from parts discounters . com with proper past number in hand. The bits are cheap and might as well change the others too.
Old Sep 24, 2015 | 10:09 AM
markwemple's Avatar
1998 E320 Wagon
Do you have the parts numbers??
Old Sep 26, 2015 | 03:16 PM
2001 E55 OMG
My part numbers may be a bit different being an AMG although I am not sure. The online EPC has the best resource for parts of you.
Requires CC but its free
http://epc.startekinfo.com/epc/
