Ever heard clunking in headliner?
Old Feb 23, 2004 | 09:58 PM
ChrisR's Avatar
E320
Angry Ever heard clunking in headliner?
When ever I hit a bump in the road, I hear a clunking overhead as if a cable is hitting the top of the roof. Does anyone know what this could be? If so, how do you fix it?
I am a little concerned about taking the headliner down since my car has side curtain airbags. Has anyone ever removed their headliner?
Thanks in advance for your help.
Old Feb 23, 2004 | 10:20 PM
MBZ12's Avatar
'07 R350. '05 C230. '93 454SS Truck. '71 Chevelle SS.
More than likely it'll be the sunroof cover jarring loose that's causing the banging. It's been a recurring theme with our cars. Mine does it every once in a long while. Someone mentioned that the dealer will take care of it by fitting a felt strip on both sides.
Old Feb 24, 2004 | 09:05 AM
E55 KEV's Avatar
Veteran: Air Force
2024 GLE63s / 2016 GLE63s (traded) / 2016 E63s / 2002 E55
Sunroof, Sunshad and headliner rattles are the most annoying thing on the W210. So many people have rattles coming from the roof. I had rattles in my 98 E430 and still in my 02 E55. I have had each car fixed and repadded and the rattles over bumps seem to never stop. Somethings I hate to even used my roof sunshade or my sunroof.
Old Feb 24, 2004 | 11:38 AM
jimmydagreek's Avatar
2022 CLS450 AMG 4Matic
Yeah, I'm really glad I don't have a sunroof but the stupid rear window shade used to rattle all the time so I stopped using it and tinted my windows. Good luck on the sunroof Chris...
Old Feb 24, 2004 | 05:21 PM
jago1244's Avatar
2016 G63 ; 981 boxster GTS
mine was fixed at dealer..
added padding and changed sunroof 'cassette'
been ok for most of a year.
Old Feb 25, 2004 | 05:20 AM
E430_4MATIC's Avatar
1973 280SEL 4.5; 2021 E450S4 Wagon
Jago1244, What is the sunroof 'cassette'? Are there any part numbers on your invoice for this repair?
Mine continues to rattle despite being at the dealer 3 times for this. They've added the felt tape but it's not enough.
Thanks!
2000 E430 4Matic
Old Feb 25, 2004 | 11:47 AM
E55 KEV's Avatar
Veteran: Air Force
I had my entire sunroof bracket replaced on my E55 and still some rattles. Main sore spot for W210 models.
Old Feb 25, 2004 | 10:08 PM
redcoupe's Avatar
11 ML350
Try tapping on the back of the headliner before the rear dome light and see if it makes noise. I have replaced headliner for this problem.
You can fix it your self by pushing thin foam up in that area.
Brian
Old Feb 26, 2004 | 10:17 PM
jago1244's Avatar
sunroof 'cassette'
Thanks!
2000 E430 4Matic
hi, e430, found the invoice, i was slightly mistaken, they didnt replace the 'cassette' , but said "FOUND LIFTING BRACKETS IN CASSETTE LOOSE" and "adjusted and secured sunroof frame".
i see they also applied felt tape p/n 000-983-89-10 (i guess tape is tape).
i would assume the cassette is simply the frame around the sunroof mechanism. no part number indicated. sorry.
also, a long shot..if you keep your rear headrests down, they may bounce against the rear deck, creating another noise on bumps..i keep my middle one always down, and stuck some bubble wrap under it
good luck , j
Old Feb 26, 2004 | 10:46 PM
The Godfather's Avatar
4 wheeled car.
wheni turn up the stereo it rattles like a mother! I hate it! I gotta get it looked at.
Old Feb 27, 2004 | 12:45 AM
Whitey's Avatar
98 W210 Advantgarde
You mean your ICE is blowing away the roof????!!!!!!
Old Feb 27, 2004 | 02:05 AM
4 wheeled car.
pretty much
