Gruppe M Carbon Intake on my Benz…Yeah...
There are many solutions online how to mod your car’s intake system. Some say that it is proper to install aluminium tube with cone filter and that’s all. Some say that you must put your filter under the front bumper, close to the fog lamp to get true cold air and e.t.c.
Doing this job, first goal for me was to get more cold air for my engine, I know that more effective cold air and more effective exhaust system allows car to breath better and it’s = more hp, better performance. P.S. Also Ecu tuning has a big meaning in this job. Also I didn’t want to modify my cars intake system so that it has a whole custom look, I prefer factory look or brand parts (which aren’t cheap).
My car is 00 E430 with factory 279HP 400NM V8 M113.940 E43 engine. But it has the same air intake setup as W210 E320, E280, E240, and I think it isn’t right. Other side on W208 this engine already has 2 tubing intake (AMG style). For Example E430 has 109 hp more than e240 and both them have same air intake setup…. ‘’Mercedes Marketing’’. Same filter, same air box, same tubing, only M113 MAF is bigger. That’s why I decided to modify it to open my engines potential.
Before starting report about new intake install. I want to talk about air filters. On my car after removing cats and resonator, I installed AFE Magnum Pro dry S air filter, it is drop air filter. Against to the stock man filter I want to say that there was 0 difference in performance. I paid about 70$ for this filter without shipping, and get no gains in performance. I haven’t done any dynos and e.t.c. but I can feel my car, and it’s truly that this filter didn’t work for me. (P.S. I've this filter for sale now, if anyone is interested PM).
Many years ago I read online that Gruppe M makes awesome intake systems. As i know they are oriented on BMW’s but also have some stuff for Mercedes. So I started to search Gruppe M intake for my car. Also i know that there is installed rechargeable K&N air filter inside of carbon fibre box. After long searching i finally found one whole setup which was for sale in my country – Georgia. It was installed on BMW E39 which was imported here from Japan. Only thing about i warried was will it fit to my Air flow sensor housing? When i met to seller we measured everything and it fitted perfectly, everything was bolt on, i only have to make mounting piece of steel longer to mount the carbon fiber box to my car.
Two days ago we installed this Gruppe M intake on my car and what a difference. When i fired up my engine after installing and push my accelerator, i feel that car idles more easy, accelerator is sharper and what a sound it makes…. Superb…. Then we went on a test drive. The seller was with me and when i did kick down the esp lamp was blinking even on 70km/h. On lower gears car speens it 18 inch wheels like crazy, even with esp turn on. So i am very pleased with this mode. Online some guys say that Gruppe M doesn’t add performance on car, exactly same told me the seller, but when we were driving in my E430 with this intake installed he told that he wasn’t right about Gruppe M’s performance abilities.
ON E39:
On W210:
Furure Mods: 82 MM trottle body, E55 Cams, and Ecu tuning...
This is a factory hole. From here cold air goes to the engine. Inside this hole under the hood near the headlamp is mounted plastic coupler which connects it to the lower air box. I've modified this plastic piece such that when car moves cold air hits straight to the intake and then goes to the engine ☺
1) Added some triks for more cold air;
2) Made mounting bracket of the Gruppe M;
3) Finally made the heat shield, which is very important for me.
Here is the setup:
Info about my next mods coming soon... (E55 Cams + 82MM M272 T/B)
Hello. Here is the setup how my exhaust setup looks:
This is my friends modded C32 AMG... My E430's setup looks like this, all cats deleted and resonator deleted, they are replaced with SS straight pipes. As i remember the cats are replaced with 60mm tubes and on the place of resonator there is installed 70mm tube on my car. As you can see i have no X pipe, i have Y pipe + AMG Back Box with 1 inlet tube.
Keep it up! Sounds great
Now i'm gonna change my cat back pipe to 76mm pipe. (now it is about 60mm, on picture i wrote that it was 70mm but it was my fault) and also change sec.cats pipes which are 50mm to 60mm pipes... Sound clip will be soon
ON E39:
On W210:
GOT DAMMMMMMMMMMMMMMMMM!!!!!! I LOVE IT
I WANT FOR MINES
1998 MERCEDES-BENZ E430 SPORT
780 DOLLARS FOR GRUPPE
DAM I NEED ONE
NICE WORK BRO
