Reset oil service light on 2000 MB 320e
Old Apr 2, 2016 | 10:54 PM
Uhenry1's Avatar
2000 E320 4Matic
Hey guys so I did an oil change on my car after going over 9k miles and I tried to reset the service using youtube and won't rest at all. The service B exceed 30k miles never reset before when I bought the car from my relative. Please help. Here is the YouTube and try different YouTube videos but no help.
Old Apr 3, 2016 | 11:45 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
Do you have manual for your car?
The video shows how it works, what doesn't in your case?
Old Apr 6, 2016 | 01:54 PM
Uhenry1's Avatar
2000 E320 4Matic
update, I do no had the manual for my 2000 MB E320 4Matic. When I try to press R for couple minutes or more, nothing happen.
Thanks Henry
Old Apr 6, 2016 | 01:57 PM
kajtek1's Avatar
Is your R button working on resetting daily meter?
It is long shoot, but for older models it is required to start the procedure from "sleep" mode.
Meaning close the doors, wait for cluster display and lights to go off and then start the procedure.
Old Apr 9, 2016 | 09:56 AM
Uhenry1's Avatar
2000 E320 4Matic
Kajtek1, still doesn't work maybe take the car to be dealership next oil change to see if dealer can reset.
Thanks Henry
Old Apr 9, 2016 | 01:12 PM
kajtek1's Avatar
SD should reset it with no problem, but lack of reset now- will show in car memory if that matters to you.
I would keep trying and making sure you follow each step 100%. It is common that one misstep, or waiting a second too long would scramble the procedure.
Old May 22, 2016 | 10:43 PM
flya9's Avatar
1999 E300TD
I had to use the "0" button on the lower left. Turn ignition on two clicks, push twice in 4 seconds, switch ign off, then hold the "0" button down while you turn ign back on. Wait about 10 seconds and it reset. I tried doing 4 button pushes in 4 sec but that didnt work for my car.
Old May 23, 2016 | 01:18 PM
raymond g-'s Avatar
99 E320
that won't work for the purpose of this thread as the OP has a 2000 whereas
your model is 1999 and utilies a different FSS resetting system.
Old Jul 21, 2016 | 07:04 AM
Djdeo's Avatar
2010 GLK 350
No manual unfortunately any way of obtaining one?
Old Jul 21, 2016 | 12:23 PM
kajtek1's Avatar
MBUSA still supplies electronic manuals down to MY 2000.
Sorry prelifts
http://www.mbusa.com/mercedes/servic...owners_manuals
Old Aug 8, 2016 | 06:14 PM
Richard / E320's Avatar
2001 E320
A few quick-hints and some information reminders from the Owner's Manual, 2001.
http://www.geocities.ws/mymercedesbenze320/
