Replacing spring pads: True or False!!!!
Old May 12, 2004 | 04:59 PM
MikeyE430's Avatar
2010 E63 AMG, 2000 E430 Sport, Dodge Charger SRT8
HELP!
When replacing the REAR spring pads on a 210 E-class suspension, do you have to loosen and drop the rear sub-frame (carrier), can you use a spring compressor, or is there a better method? My dealer says the sub-frame has to be dropped. They didn't drop the sub-frame when they installed the springs. What gives?
Someone PLEASE provide me with some info. quickly. Car goes to dealer tomorrow (Thursday). THANKS!
Old May 12, 2004 | 09:10 PM
Fanatic's Avatar
an import
Mikey
This is a moot point isn't it?!? You're changing the sway bars as well and definitely they have to drop the rear sub frame to get the back bar in and out.
(assuming that the dealer is going to install the H&R for you)
Old May 13, 2004 | 09:15 AM
MikeyE430's Avatar
The guy at Tire Rack said you could install the rear bar without dropping the subframe. He said you can "fish" it through. I don't know.....that is why I need more info. from you guys.
Old May 13, 2004 | 11:19 AM
jimmydagreek's Avatar
2022 CLS450 AMG 4Matic
I don't know if our rear ends are the same but all I had to do was remove the control arm slowly with a jack, pull the spring out, replace it and then raise the control arm back up with the jack for bolting. Check out the pics...(excuse the dirt please as I did this during winter and after all the rain we had, hehe)
Removal of control arm:
Removed:
Spring/shock/pad assembly:
Pad w/spring removed (also new camber arm pictured):
Pad on spring:
Old May 13, 2004 | 03:29 PM
kicker's Avatar
E320 2000 w/GPS
#2 pad?
that looks like #2 spring pad isn't it?
I'll try to change my rear spring & shocks tonight or tomorrow. will see how it goes.:p Hopefully everthing will be a breeze. I did the front ones last week, took a little while!! I don't know what number spring pad I have in the back. but will find out soon. thanks for the pictures Jimmy..
Old May 13, 2004 | 04:23 PM
kicker's Avatar
E320 2000 w/GPS
Re: Replacing spring pads: True or False!!!!
Originally posted by MikeyE430
HELP!
Mike,
I would say you need to use 2 jacks to do the spring drop like what jimmy posted. I am planning to do that either today or this weekend it should be much easier compared to do the front springs.
Old May 13, 2004 | 05:08 PM
Re: Re: Replacing spring pads: True or False!!!!
Originally posted by kicker
Mike,
You only need to use 1 jack and a pair of jack-stands. The rear will be a lot easier than the front and yes, those are #2 pads...
Old May 13, 2004 | 05:43 PM
JamE55's Avatar
Out Of Control!
I have #1 Pads all around! And pretty with it.
Old May 13, 2004 | 08:14 PM
Richard Galing's Avatar
W210, W220, W163, W164, C6
DITTO!
Old May 13, 2004 | 09:56 PM
Fanatic's Avatar
an import
Mikey,
Jimmy is right. You don't need to drop the rear sub-frame to do only the rear springs and shocks.
What I was refering to was that since you are going to change out the sway bar, they will have to drop the sub-frame to do this job. I would question Tire Rack on this. I have spoken to two different shops and the dealer in my area and they all say to drop the rear frame. I took a look the last time I changed my tires and there would be a lot of 'fishing' going on to get that rear bar out, nevermind 'fishing' in the new thicker bar. I hope the Tire Rack rep wasn't Luke as he normally knows better than that.
Old May 14, 2004 | 09:32 AM
MikeyE430's Avatar
Yep, it was Luke. Thanks for your info.
