Oil Pan Gasket?
Pretty darn good stuff as I bent lip on steel pan trying to pry it off.
Tip on installing covers with RTV - don't overdo it, tight it up fresh with finger-torque only, let dry overnight and torque the following day.
Note - the cleaning and sealant products are the same as used for the vent chambers on the valve covers and other joints. Also, make sure it is fresh. Don't use if it is over 1 year old.
I know... I know,,. he is out of control.
