How best to clean an enclosed part with a check valve
Old Jul 19, 2018 | 07:42 PM
CanuckMerc's Avatar
2001 E320 4Matic
Hey folks. Meet a real pain in the ***.
This here is an evap check valve from a 2001 e320 AWD wagon and thankfully most of you won't find this on your vehicle as this car is a Japanese made model and this piece is an extra over and above part on top of the charcoal canister for emissions standards that yes also includes that pesky plunger valve that goes bad as well.
In my case I've replace the purge valve under the hood and then replaced the plunger valve on top of the canister. Everything was fine for about a week and the mass emission leak code that was preventing me from passing a test for car registration was fine. Then like mentioned after a week I got a P0446 code and this puppy is the reason.
I've pulled it to clean as this little gem is worth over 400 bucks, generally around 500 and change if you're unlucky as I am to have a Japanese version. Of course they have much higher emission standards than we do.....mind you they sure didn't apply that thinking to their nuclear reactors did they? Too soon? Sure, I'm frustrated.
In any case now I have to clean this thing somehow. But it seems like a self enclosed jobbie, so I'm here to ask you all what would you clean the interior with? Soak the inside in WD 40? Leave it overnight and then dump and let stand for a day?
Thoughts?
Old Jul 19, 2018 | 07:57 PM
CanuckMerc's Avatar
2001 E320 4Matic
And the winner is......
Mass Air Flow cleaner. Because I literally live on the ridge of the Manzano mountain range and 15 miles from the nearest civilization!
....and it's all I got.
Cross your fingers folks. If this works...well then it works
Old Jul 19, 2018 | 08:54 PM
Strigoi's Avatar
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
Neat, another new thread about the same thing you keep posting. Your journey and posts with this would have been 100% more helpful for people doing searches if you kept it all to 1 thread. Instead you post a new thread for every new revelation that you have on this part that most people won't have to deal with.
Old Jul 19, 2018 | 09:45 PM
CanuckMerc's Avatar
2001 E320 4Matic
Oh I see, sorry to offend your forum etiquette Mr. Blackwell. I'll make sure this is the last post here. And I won't be back.
Old Jul 19, 2018 | 10:01 PM
Strigoi's Avatar
Can't take some constructive criticism? How is splitting a problem into several separate threads more beneficial than making one thread and updating it?
I don't give two ****s about the problem you're having, but it's a somewhat unique one and people could be helped (years from now probably) if it's easy to find all of the info needed in one thread.
I'm sorry some common sense was a such a blow to your personal worth that you won't post on here anymore. If you're that easily upset you don't belong on forums. Sorry I didn't coddle you and try to not hurt your feelings. Go see your mommy, she'll make everything ok.
Old Jul 19, 2018 | 10:05 PM
CanuckMerc's Avatar
2001 E320 4Matic
Hey why don't you take a f**kstick trip off to f**kity f**k land? And when you get there, tell the bellhop that he should take two trips to lug your f**k stick luggage up to your penthouse.
Oh sorry forgot to add f**ckhead.
Old Jul 19, 2018 | 10:09 PM
Strigoi's Avatar
And there we go....
Why does your reply not surprise me?
Old Jul 19, 2018 | 10:27 PM
CanuckMerc's Avatar
2001 E320 4Matic
And there we go....
Because you're a f**ckhead. Now f**ck off or do you need that in a separate thread f**kstick?
Old Jul 19, 2018 | 10:45 PM
Strigoi's Avatar
Maybe? I'm not totally sure what you mean by ****stick. Are you talking about ******?
Old Jul 20, 2018 | 01:37 PM
cm60k's Avatar
C,mon fellows,, no need to go that route..!,,
helping guys here is the MAIN GOAL..
-;ZAYED;-
Old Jul 20, 2018 | 02:44 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
-;ZAYED;-
Seeing Plutoe having administrators support, I am not sure about it.
Coming to original question. If the valve has gasoline- based build up, you can buy safety fluids to dissolve it, or even kerosene should do it.
Any picture of the interiors? The android snake cameras cost like $10 and that would be good point to use one.
Old Jul 20, 2018 | 02:53 PM
cm60k's Avatar
Who's the administrators you refers to..?!?!
-;ZAYED;-
Old Jul 20, 2018 | 03:41 PM
cm60k's Avatar
I talked to my friend who cleaned that valve before, he said; he used contact cleaner, then blows air in it,,
it's back to life, no issue with it, since that day..
-;ZAYED;-
Old Jul 20, 2018 | 05:36 PM
CanuckMerc's Avatar
2001 E320 4Matic
-;ZAYED;-
1) yes you're right Zayed and thanks to you the car is now fixed. No codes, no check engine light. The emissions system is 100 percent. I cleaned that evap check valve with MAS airflow and I literally soaked it in all the ports until that stuff was running out like water.
2) yes you're right I should have lost my cool with that f**kstick who came in and started giving me a hard time about not having my threads in the right place. I'll ignore him next time! Thanks Zayed your help was instrumental and for the first time in 3 years there's NO check engine light on my car and ZERO codes from my Actron OBD scanner
Old Jul 20, 2018 | 07:17 PM
cm60k's Avatar
Soooo glad you beat it bro.,
believe me, "Strigoi", is such a good guy, he helping many guys including me, especially on AMG section,,
but sometimes damn anger with misunderstanding jumped up to us..
-;ZAYED;-
